Cannot Fix Electrical Humm/Buzz - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 09:34 PM   #1
I have a 3 bulb light fixture in my kitchen and for 4 years it was on a dimmer switch and everything worked fine. Not knowing about the incompatibility of dimmer switches and regular CFLs, I installed regular CFLs into the fixture and it started to produce an electrical buzzing noise. I could not turn this noise off when the switch was off. I removed all of the bulbs and that still did not fix the noise. I then learned about not using CFLs with dimmer switches, so I replaced the dimmer switch with a normal ON/OFF wall switch. It fixed the problem for awhile, but now the buzz is back again. Turning the wall switch off and/or removing all of the CFL bulbs does not stop the buzz. If I switch the power off at the circuit breaker, the buzz will stop, but it comes back when I turn the power back on at the breaker. It seems to me that the wall switch is bad again. If so, what kind of switch do I need to work with CFLs? If the switch could be ok, does anyone have any ideas what might be causing this problem? Thanks!
Simursmack is offline   Reply With Quote
Old 01-20-2012, 02:42 AM   #2
There could be a loose connection. If you replaced the switch and the buzz was gone for a while, thats where I would start checking.
jammin06 is offline   Reply With Quote
Old 01-20-2012, 08:39 AM   #3
joed's Avatar
Rewards Points: 11,560
There is something else on the circuit causing the buzz.
A buzz could be from a loose connection arcing but that would only buzz when power was going through it.
A door bell transformer could be buzzing.
A bad switch would buzz at the switch not at the fixture.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 11:49 AM
