Canned Light And Soot - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 02:00 PM   #1
Canned light and soot
Hi everyone! New to this site and already hooked and found a few really helpful posts. I did search for this issue, and was not able to find anything related.
In my kitchen there are a few canned/recessed lights. Recently one bulb burnt out and as a result there are soot marks around the edge of the can. I feared an electrical issue, and have pulled out the can, but everything is clean and no signs of a short. So unsure if this is just a product of the bulb burning out -- assume it would smoke some while burning out OR if this is something much different and would need a professional to inspect.
In checked other canned lights, I do see slight soot marks.
The breaker did not pop when the light burnt out, so guessing there is no short in the circuit. No other lights went out at the same time, and they are on the same breaker.
many thanks in advance!
Canned light and soot-20130811_114248.jpg   Canned light and soot-20130811_114305.jpg   Canned light and soot-20130811_114319.jpg
oregonfan is offline   Reply With Quote
Old 08-11-2013, 02:23 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
The soot looks like air infiltration from the attic.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 5 Users Say Thank You to rjniles For This Useful Post:
joecaption (08-11-2013), Kyle_in_rure (08-11-2013), oh'mike (08-11-2013), Oso954 (08-11-2013), stickboy1375 (08-17-2013)
Old 08-11-2013, 02:27 PM   #3
DIY staff
Rewards Points: 7,174
Get uo in the attic and air seal the can-----aluminum duct tape--caulk or some thing like that---
Old 08-11-2013, 02:51 PM   #4
Rewards Points: 13,960
Is it an IC (in contact) can?
Is it an Air Tight can?
Should say what it is right inside the can/
What's above that area?
Old 08-11-2013, 04:08 PM   #5
Oso954's Avatar
Rewards Points: 1,296
Not only is the can an ICAT, but his trim is an airtight as well.
Why they aren't sealing doesn't show in the photo's, but Oh'Mikes recommendation is a good place to start. I would also suggest that while in the attic try to compare it to a can that is not leaking. They usually have a foam seal over the themocouple and where the flex conduit enter the fixture. If one of those is missing on the problem can, I would seal that area as well.
Oso954 is offline   Reply With Quote
Old 08-11-2013, 05:31 PM   #6
Electrical Contractor
kbsparky's Avatar
That is NOT soot, but DUST!!
Seal up the can(s) and your problem will disappear
-KB
Old 08-11-2013, 07:17 PM   #7
Many thanks all.
Sadly these are in the first floor and directly above is the second floor, so no easy method to see/inspect the cans to see about seals.
Likely the dust has always been there, just never getting any attention until the light burnt out.
Old 08-11-2013, 08:31 PM   #8
DIY staff
Caulk the seam between the can and the drywall---
Old 08-17-2013, 09:09 AM   #9
Rewards Points: 170
really simple fix... when you get the new light, apply a small bead of caulk around the top of the outer lip before you put the light in place. When the light is lifted to the ceiling, it will create an air tight seal with the drywall.
diyer111 is offline   Reply With Quote
Tags
canned light soot
Soot in Furnace - Furnace not working Snboard976 HVAC 11 02-25-2013 10:38 PM
soot normal? mmm76 HVAC 2 01-16-2012 08:49 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
