Canister Light - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 08:22 PM   #1
canister light
easiest way to fish wire between floors for can lights and do least drywall repair
slabsolife is offline   Reply With Quote
Old 09-18-2009, 08:28 PM   #2
Electrical Contractor
kbsparky's Avatar
Tie a string to cat's tail, put cat in ceiling thru one hole -- cat runs out of other hole.
-KB
Old 09-18-2009, 09:09 PM   #3
Electrician
Way too vague of a question. Too many variables involved. Type of building construction? Age of building? Balloon framed? Ceiling strapped? Chimney chase? Vent pipe chase?
Every situation is different. There are many different techniques that I use, all depends on the factors I stated above and probably a few others that I can't think of now.
EBFD6 is offline   Reply With Quote
Old 09-18-2009, 09:23 PM   #4
" Euro " electrician
frenchelectrican's Avatar
All it depending on the type of structure you have and how it layout { the joints and stud line up }
some case it will be easy shot and some don't.
Merci,Marc
Old 09-19-2009, 02:17 AM   #5
TomServo is offline   Reply With Quote
Old 09-19-2009, 03:49 PM   #6
kbsparky's Avatar
Gotta laugh every once in a while!
When we have more/useful information from the OP, I might be able to post a more useful answer.
-KB
Old 09-19-2009, 04:13 PM   #7
Cats are too large. Use a mouse.
Old 09-20-2009, 07:16 AM   #8
Rewards Points: 1,548
OT: (Live) mice are sometimes used to pull threads through conduit which thread in turn helps pull a rope and then a cable through. I assume the mice are trained in advance back at the shop.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Halo Canister Light Installation tvinson9 Electrical 5 12-30-2005 05:34 PM
