Canadian Electrical Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 04:14 PM   #1
Canadian Electrical code question
I am hooking up a unit heater. It is hot water heated and fan forced.
110vac for fan.
1. Can I use a double pole thermostat to control the fan motor and also the zone valve to the heater?
fan - 110vac
zone valve - 24vac
The thermostat is rated for baseboard electric heat and each set of poles are isolated from each other.
Therefore there would be both low and high voltage in the same box as well as the same switch. (thermostat) Is this allowed?
YK-boilerman is offline   Reply With Quote
Ontario Canada Electrical Code Question?!? njchan Electrical 4 05-10-2010 08:29 PM
Electrical re-wire to code diy-safely Electrical 8 01-04-2010 03:19 PM
Electrical Problems mirx Electrical 19 08-03-2009 09:12 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 09:43 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
