Old 11-24-2010, 11:11 PM   #1
flemingetq
Canadian Electrical Code Question
I am unable to find the Code number of the Canadian Electrical Code for the following install.
Why do the holes have to be drilled in the center of the 3.5inch wood stud. I need the Code Rule Number. I know why it has to be done, just do not know the code number.
Also are there any electrician in here from the Peterborough, Oshawa Ontario Canada area who would be looking for an apprentances starting in March 2011.
Thank you for all your help.
John Rothernel
flemingetq is offline   Reply With Quote
Old 11-25-2010, 12:29 AM   #2
Mad Scientist
Sorry I can't help you more specifically, but I can tell you I'm pretty sure that any such requirement would be in the building codes, not the electrical codes.
McSteve is offline   Reply With Quote
Old 11-25-2010, 09:39 AM   #3
joed's Avatar
12-516 (a) Cables must be 32mm from the face of the stud.
That would mean drill the hole in the center.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-25-2010, 10:22 AM   #4
Needs to be done to reduce the likelihood of screws/nails from piercing the cable and may help in not reducing the load bearing capacity of the wood member (although I imagine this is a minimal benefit).
bob22 is offline   Reply With Quote
Old 11-25-2010, 10:42 AM   #5
I=E/R
a7ecorsair's Avatar
joed answered your question.....
Same as the US. The largest drill bit you can use is 3/4" or 19mm provided you drill exactly in the middle. I've been using a 5/8" for my wiring because I can get two 12/2 NM cable through it if needed.
a7ecorsair is offline   Reply With Quote
Tags
canada, canadian electrical code
Ontario Canada Electrical Code Question?!? njchan Electrical 4 05-10-2010 09:29 PM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 11:37 PM
Electrical Problems mirx Electrical 19 08-03-2009 10:12 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
