Canadian Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 03:58 PM   #1
Rewards Points: 27
canadian code question
I read in another thread that someone said it is code in Canada to have the incoming gound wire bonded to the box in a receptacle, as opposed to the outgoing. I guess it could be for lighting or whatever
I can't find the thread, but can anyone confirm that this is code or not? I don't see it in my Knight book.
blott0 is offline   Reply With Quote
Old 12-22-2012, 06:32 PM   #2
Electrician
Rewards Points: 802
Does not matter, all the grounds in the box should be tied together.
I usually take one ground to the screw and then tie the rest together.
darren is offline   Reply With Quote
Old 12-22-2012, 07:53 PM   #3
joed's Avatar
Rewards Points: 13,752
Not sure I understand your question. Metal boxes need to be bonded to the ground. Normally in metal boxes there are enough screws to bond all the grounds to the box and leave one of them long enough to ground the receptacle. It doesn't matter which one. Ground screws in metal boxes have a raise spot beside them to allow you to put one ground wire under each side of the screw. They do not have to be wrapped.
Electrical panel code question rap4rent Electrical 10 12-18-2012 07:49 AM
Code question - Romex in garage billman5000 Electrical 11 11-29-2012 05:58 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
Canadian Electrical code question YK-boilerman Electrical 0 11-26-2010 04:14 PM
question about code chrissy2008 Electrical 14 02-01-2009 09:48 PM
