Canada Ontario Bathroom Bathtub Chandlier, Proximity Switches To Bathtub - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 12:01 PM   #1
Canada Ontario bathroom bathtub chandlier, proximity switches to bathtub
I've see the drawing for lights/chandelier over bath tub (in forum) but I think this refers to USA. See drawing. #3 is gfi with 1, 2, 9, 4 being tapped off 3. # 3 would be dedicated from panel at 15 amps. #5, 6, 7, 8, 10 would be another 15 amp dedicated 15 amp non gfi.
Questions: A) Can I have chandelier over bathtub?
B) Are switches too close to bathtub? If yes can switch be outside the bathroom
C) Because only switch 4 is gfi protected can I still use a 3 gang box?
D) Kitchen: Any rules regarding distance from sink for a non gfi switch controlling lighting?
Input regarding Ontario electrical code refering to above would be appreciated.
I have uploaded a compressed drawing of bathroom.
Jan
janluthe@hotmail.com
Canada Ontario bathroom bathtub chandlier, proximity switches to bathtub-bathroom-electrical-compressed.jpg
Janluthe is offline   Reply With Quote
Old 04-17-2012, 02:20 PM   #2
joed's Avatar
Rewards Points: 13,728
Chandelier must be approved for use in a wet location.
Switches are not permitted closer than 1m to a tub or shower. If they must be closer then .5m is the minimum and they must be GFCI protected.
There is no code on kitchen switches in proximity to a sink. Receptacles within 1.5m have to be GFCI protected.
The Following User Says Thank You to joed For This Useful Post:
Janluthe (04-17-2012)
Old 04-17-2012, 02:47 PM   #3
Joed:
Thanks for the quick reply.
A) If 3 switches are between 1 and .5 meter from bathtub, is it good enough that only 1 item is GFCI protected in a 3 gang box with 3 switches? Does one gfci item protect the hole box?
B) "Approved for wet location": Does this mean that it has to be waterproof like for showers?
C) I can understand having a 'waterproof' light in a shower, however, lots of lights above vanitys are standard 'spot lights'. Is it because it is above a soaker tub that it has to be approved for a wet location?
Jan
Old 04-17-2012, 03:06 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by Janluthe
Joed:
Jan
B)Yes
C)your stepping into a tub full of water and loose your balance,out of instinct you reach and grab onto the chandelier which is on!
Lets just say it would probably be the last bath you'd ever take.
sublime2 is offline   Reply With Quote
Old 04-17-2012, 06:02 PM   #5
joed's Avatar
a. All switches need to be GFCI protected. If they are all on the same circuit then one GFCI can do it.
Old 04-17-2012, 06:06 PM   #6
joed's Avatar
From the ESA FAQ site.
http://www.esasafe.com/faqs.htm
Question
Does the Code permit a light fixture to be installed in a shower?
Answer
Yes, as long as the fixture is approved for wet locations.
Rule 30-318.
Ontario Electrical Safety Code 24th Edition/2009.
Question
Does the Code require GFCI (ground fault circuit interrupter) protection of a light fixture located in a residential tub / shower enclosure?
Answer
No, the Code does not require GFCI protection, however if the fixture manufacturer's installation instructions require GFCI protection, then the Code requires that the instructions be followed.
Rule 2-034.
Janluthe (04-18-2012)
Old 04-18-2012, 10:17 AM   #7
Thanks joed especially for the link to ESA. It gives me another source to search for info.
Jan
Old 04-18-2012, 10:21 AM   #8
Rewards Points: 14,306
I can see a Chandlier being a night mare to keep dust free in a bathroom.
All the hot moist air in the room will make any dust in the air stick to it.
Need help wiring switches to bathroom light and fan Kid Quick Electrical 31 01-08-2012 08:30 PM
Help needed: replacing bathroom fan/light & switches. bkboggy Electrical 12 12-28-2011 10:07 PM
Bathroom switches ryanwm1978 Electrical 3 06-23-2011 08:43 PM
Bathtub drain in a new basement bathroom flynryn Plumbing 1 05-28-2010 05:00 PM
bathroom power switches relative to bathtub amakarevic Electrical 7 10-14-2008 03:07 PM
