In Canada Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 02:03 PM   #1
in canada grounding
my 2nd. floor bathroom has no grounding .Is it ok. to connect one wire from cold water pipe to the outlet? My break panel is grounded to the main water pipe.All 1st floor and basement are grounded. Thanks
gefeiora is offline   Reply With Quote
Old 11-10-2010, 02:10 PM   #2
Handyman
Rewards Points: 512
I would just install a GFI outlet.
canadaclub is offline   Reply With Quote
Old 11-10-2010, 03:19 PM   #3
thanks,Canadaclub, the box is too small and is very hard to work. is too close to the mirror .But is it safe to use a wire.? May be what i would do is install a box with a gfci receptacle, right after the panel, and i think the hole circuit will be protect. thanks again
Old 11-10-2010, 03:32 PM   #4
Handyman
Rewards Points: 512
Yep, a GFI breaker will work
Old 11-10-2010, 05:38 PM   #5
joed's Avatar
Rewards Points: 13,276
Grounding to a metal water pipe is permitted in Canada. GFCI is also required within 1.5m of the sink.
Old 11-10-2010, 05:58 PM   #6
Handyman
Rewards Points: 512
Only if you are sure that it is copper all the way to the earth
Old 11-10-2010, 10:09 PM   #7
thanks for yours replies. A gfci breaker would the best. unfortunately,it is discontinue, could't find any.i will try with the wire (only 1m),and take the cable from the panel connect to a box with a gfci receptacle and than connect back to the breaker, that way i think that circuit will be protected .thanks
grounding electrode conductor question bsperr Electrical 8 12-05-2009 09:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Grounding light box n0c7 Electrical 10 10-06-2008 03:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
