Can You Wire Multiple Outlets Like This? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 09:19 PM   #1
Can you wire multiple outlets like this?
Is this ok to do?
toobhed is offline   Reply With Quote
Old 08-02-2011, 09:33 PM   #2
Licensed electrician
Rewards Points: 1,456
That way is fine.
Old 08-02-2011, 10:16 PM   #3
Thadius856's Avatar
Rewards Points: 504
Sure hope so! That's how I'm wiring the new circuit I'm currently working on. lol
Thadius856 is offline   Reply With Quote
Old 08-03-2011, 07:29 AM   #4
Rewards Points: 1,492
There is the chance that the box with the three cables coming in will be too small. Count two points for the receptacle unit, one point for all the grounds, one point for all clamps or fingers holding cables in the box, and one point for each wire end coming in (6). No points for pigtails (short lengths) completely inside the box, no points for wire nuts (USA rules). Total 10 points times 2 cubic inches for 14 gauge wires equals 20 c.i. box minimum size.
Old 08-03-2011, 07:32 AM   #5
joed's Avatar
Rewards Points: 12,334
That is the standard way of wiring receptacles.
Old 08-16-2011, 09:48 PM   #6
Good to know. I am running 12/2 for the outlets. I believe the c.i. multiplier is 2.25? That puts me at 22.5 inches so definitely a do over.
I have no clamps, what are fingers? Do dimmer switches also count as 2?
Old 08-16-2011, 10:11 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
I think he means the molded in grips that hold the cables. I personally do not feel cable grips like that are taken out for box fill. Only additional or internal clamps are. Cable grips that are molded into the box are already figured into the actual cu/in capacity of the box.
And yes, any "yoke mounted device" counts are two "conductors".
Old 08-16-2011, 10:14 PM   #8
Sometimes the "clamp" is a plastic finger molded as part of the box and just inside the hole and is pushed aside a little as you insert the cable.
By code a dimmer switch also counts 2 points but you need to be careful because it can be hard to stuff everything into the box. You really should get a bigger box if the point count is near the limit and you also have a dimmer switch or GFCI receptacle.
Old 08-16-2011, 10:20 PM   #9
Thank you thank you! I get it now
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Multiple Outlets From One Source (14-2) J.A.M Electrical 5 02-08-2010 07:39 PM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 08:46 AM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
