Can You Use Wire Nuts On A Fan Light Switch With Silvery Looking Wires? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 11:14 AM   #1
Rewards Points: 320
Can you use wire nuts on a fan light switch with silvery looking wires?
As you can tell by the title of the post, I don't know anything about electrical stuff and I will call an electrician for major repairs. But this is a small repair so I wanted to do it myself. I had to switch out a pull chain light switch from my ceiling fan since the chain broke from the switch inside. When I went to wire the new switch in I just cut the wires and taped it with electrical tape to the wires in the fan (please tell me if it is unsafe to use electrical tape to tape wires together, I heard mixed things about electrical tapes uses). Works fine though.
Now another pull chain broke in my condo from another ceiling fan, and I wanted to use wire nuts instead of electrical tape to attach the wires together. The wire nuts say to only use on wires that are copper and not aluminum. I think the wires are copper since when I cut the wires the tips of the metal wires where they are cut look copper colored, but the length of the metal wire itself is silvery colored.
Is it just copper wire coated in something else? If so, what is the coating? And where would I even find aluminum electrical wires?
Bottom line, can I use wire nuts on this repair to attach wires? Can I keep the electrical tape in the other fan I repaired as well or is that unsafe?
Thanks a bunch for the help!
amodoko is offline   Reply With Quote
Old 10-28-2012, 11:31 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm not 100% sure what the fixture wires are, but I wirenut them without hesitation and there hasn't ever been anything in any instructions that say you can't. I've never been that curious to care. Adding to that, most fixtures come with standard small orange wirenuts.
You cannot use tape in lieu of wirenuts.
The Following User Says Thank You to k_buz For This Useful Post:
amodoko (10-28-2012)
Old 10-28-2012, 11:34 AM   #3
[quote=amodoko;1039566]When I went to wire the new switch in I just cut the wires and taped it with electrical tape to the wires in the fan[quote]
First, you should always use wirenuts as taping won't guarantee a good bond over time. Second, anytime you join aluminium with copper, you either have to use special wire connectors or add noalox to the nuts.
Dissimilar metals will over time corrode and start a fire.
duckdown is offline   Reply With Quote
The Following User Says Thank You to duckdown For This Useful Post:
Old 10-28-2012, 03:43 PM   #4
Master Electrician
Rewards Points: 3,866
They're most likely tinned copper conductors, not aluminum.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 10-28-2012, 08:26 PM   #5
Rewards Points: 320
Hey, thanks guys, I will definitely go get the correct wire nuts now. And the tinned copper makes sense. Thanks so much for the help, much appreciated
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 02:18 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 07:04 AM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 06:41 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
