Can You Test A Non GFCI Plug With A GFCI Tester? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 05:30 AM   #1
DIYguy2000's Avatar
Rewards Points: 93
Can you test a non GFCI plug with a GFCI tester?
There is a regular outlet in our master bathroom next to the sink. The plug type is not a GFCI outlet. However, in our kitchen, there is only one GFCI plug next to the sink, and the other outlets must be wired through that one GFCI because when the one is tested, the others go out as well.
Can I used a GFCI tester on the regular outlets in the kitchen which would cause the main GFCI outlet trip? will this cause any damage?
Can I also use it in the master bathroom to figure out if that one is also wired from another GFCI outlet? (The main bathroom is right beside the master, and there is a GFCI outlet in that bathroom.)
If the outlet in the master bath is not coming from another GFCI plug, I will change it.
Thanks!
DIYguy2000 is offline   Reply With Quote
Old 01-16-2012, 06:02 AM   #2
Remodeling Contractor
yes you can
Old 01-16-2012, 06:21 AM   #3
DIYguy2000's Avatar
Rewards Points: 93
If it is not wired from the GFCI in the main bathroom, will it just trip the breaker?
Old 01-16-2012, 06:49 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 528
It will do nothing.
jbfan is online now   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci receptacles wire continuity test Hialeahn Electrical 4 03-05-2010 06:52 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
