Can You Tell? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 10:58 AM   #1
Rewards Points: 107
Can you tell?
Can you tell from looking at a light switch if it is knob and tube wireing? I know there is existing knob and tube in the house, but was told its all old and not active anymore. I can see alot of the wiring throughout the house is encased in a black cloth with a silver looking paint on it.
Also what does Aluminum wiring look like? I have a dead outlet that my father-in-law said was aluminum but we cant tell for sure. I have 3/4 of the house with 2 prong outlets, but the metal boxes they are housed in are grounded direct to the box.
Mr Smiley is offline   Reply With Quote
Old 08-03-2011, 11:25 AM   #2
Sparky
Rewards Points: 510
http://en.wikipedia.org/wiki/Knob_and_tube_wiring
Aluminum wire will look silver, copper looks orange.
Techy is offline   Reply With Quote
Old 08-03-2011, 12:24 PM   #3
joed's Avatar
Rewards Points: 12,442
And old copper wire can be tin plated and look silver. I would say if you have two prong receptacles then the old K&T has not been all replacecd. Who would put old two prong receptacles back on a new grounded circuit.
Old 08-03-2011, 12:28 PM   #4
Licensed Pro
The knob and tube could have been replaced prior to the requirement of grounded circuits.
You can sometimes identify K&T at a switch or receptacle by looking to see if the wire enters the box as a single wire surrounded by a black loom material. This is not always definitive because many times the K&T will be tied to a two conductor cable for runs to switches and receptacles.
Old 08-03-2011, 12:44 PM   #5
Rewards Points: 6,652
Not true. Not all ungrounded circuits are knob & tube. My house had BX, and used two prong outlets.
Old 08-03-2011, 12:45 PM   #6
No, there is no way of knowing by just staring at the wall.
Old 08-03-2011, 12:49 PM   #7
Rewards Points: 107
When I look into the box i see two conductors, if i look between the wall and the metal box i see a black wire with a silver paint look to it. I believe its cloth and am 100% sure its not plastic coated. The inspection stated we have K&T in the attic but we were told by the owner its dead. Maybe ill have to make sure for myself. I know they had a fuse pannel up untill 2005 when they installed the 200 amp box that is now full.
Old 08-03-2011, 01:01 PM   #8
fabrk8r
fabrk8r's Avatar
Pull the outlet and use an inspection mirror and light to look into the wall cavity to see if there are two separate conductors and if you can see the knobs/tubes.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-03-2011, 01:08 PM   #9
Rewards Points: 107
Hey I just happen to have one of those but not sure if i have the room to slide it in but Ill report back with my findings.
Old 08-03-2011, 01:36 PM   #10
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Do you have x-ray vision?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-03-2011, 03:10 PM   #11
Take a picture of the inside of the panel, and lines leading to it. If you are unsure, take and put a fan up in the attic hatch to blow cool air up there for about a half hour before going in, and take a look. You can also undo ceiling lights and see if too separate leads feed to it, instead of Romex.
Knob & tube is not that hard to distinguish, because it is very distinctive, compared to older cloth & rubber covered Romex.
Old 08-03-2011, 06:59 PM   #12
electures's Avatar
Are both wires coming in the same hole or seperate holes? Are they secured to the box with a clamp or connector?
Old 08-03-2011, 07:41 PM   #13
Rewards Points: 107
Single jacketed black cloth, with the silverish paint color, then in the metal box its a black conductor and then a white conductor. When i get a chance ill get a picture of the panel with the wires going in. Should i remove the cover?
Old 08-03-2011, 08:08 PM   #14
No need. Sounds like you have ungrounded Romex. You can just have the door open on the panel if you wish when you take the photo. Remember, most home inspectors in this Buyer's market a year or two ago were not home inspectors. I would trust what they stated as much as the paperwork they gave you. Where you there when the inspection was done on the home, so that you could walk through with them? If you think that there may be live knob & tube still, climb up in the attic, or look at wiring in the basement, especially at junction boxes.
Old 08-03-2011, 08:39 PM   #15
electures's Avatar
Is the wire connected to the box with a romex connector or using the clamp? Back when that type of romex was used the electricians used to double back the ground wire and wrap it around the romex connector or around the cable clamp screw. Look closely at the clamp screw or romex connector and see if the ground wire is there.
