Can You Review This Diagram - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 06:08 PM   #16
Originally Posted by InPhase277 View Post
Is the wire with the ground really coming from the panel?
Yeah, I've traced it back to the panel. It's only about 12' from the panel in the unfinished part of the basement.
jheavner is offline   Reply With Quote
Old 10-12-2008, 06:59 PM   #17
Rewards Points: 2,350
If all you have is 12', why not run an all new grounded circuit to what you want, and leave this one alone?
Old 10-12-2008, 10:37 PM   #18
That's actually what I was going to do when I found the junction box. I'd pulled the drop ceiling out below the receptacle and found the junction box and thought maybe I could just leverage the existing romex. I originally was going to upgrade the entire circuit but a decent amount of the wiring is behind finished walls/ceilings. I will eventually fix it but grounding just the one receptacle is a higher priority (and an easier fix).
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 08:14 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Does this wiring diagram work? beezlebub03 Electrical 7 05-04-2008 11:54 PM
