Can You Read An Electric Meter? - Electrical - DIY Chatroom Home Improvement Forum
View Poll Results: What is the correct reading on this meter?
19597 3 6.52%
18487 1 2.17%
08586 4 8.70%
08486 35 76.09%
09497 0 0%
None of these - post your answer in a reply 3 6.52%
Voters: 46. This poll is closed
Old 04-10-2010, 08:17 PM   #1
Electrical Contractor
kbsparky's Avatar
Can you read an electric meter?
Can you properly discern the meter reading here?
-KB
Old 04-10-2010, 08:29 PM   #2
I can read mine...its digital
Old 04-10-2010, 08:41 PM   #3
Paelectrican is offline   Reply With Quote
Old 04-10-2010, 09:02 PM   #4
Rewards Points: 502
My new one from upgrading to 400 amp service is all digital too.
At first glance it does appear to be 18586....but there are a couple of signs why it is not.
For instance, since the gauges spin faster to slower from right to left, we know that since the 2nd gauge is an 8, it means the very first (far left) hasnt gotten to 1 just yet.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 04-10-2010, 09:56 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I'd call it 08487, even though it's not quite there yet.
On a side note, if you have a spinning disc type (like pictured above), and you want to know the actual watts presently being consumed, just multiply the Kh constant by 3600, then divide the result by the number of seconds it takes the disc to make one full revolution. The result is actual watts.
For example, on this meter the Kh is 7.2, X 3600 = 25920. If it takes the disc 3 seconds to make one revolution, 8640 watts is presently being consumed. (25920 divide by 3 = 8640).
This formula works on all disc-type meters, but if there are CTs and/or PTs involved, you'll need to factor in their ratios.
Rob
micromind is offline   Reply With Quote
Old 04-10-2010, 10:04 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
although it looks like the pointer is on a higher number in the first position and the 3rd position, if you look at the digit following each of those, the pointer is just shy of the 0 position. As such, it is like a clock. As the minute hand runs around, although the hour hand may be pointing nearly exactly at a number (e.g. 9), until the minute hand reaches 12, it is still 8:XX. same thing with the meter dials.
I see where you got your info on the watts calcs, MM but here is a question maybe you can answer;
at the top of the dials, it is printed on there:
Rr 13 8/9
any idea what that means, if anything?
Mine says Rr 27 7/9 and is a Schlumberger brand.
just curious.
Old 04-11-2010, 12:11 AM   #7
Idiot Emeritus
The Rr stands for Register Ratio.
The disc is connected to a shaft that has a worm gear on it. This worm gear meshes with a wheel-type gear. The Rr number is the number of turns this wheel gear makes in order to turn the first dial one revolution.
The Rr number seems to vary with different manufacturers as well as different styles. It's usually some dumb number too; like 13 8/9 or 11 5/7. Wouldn't something like 8 or 12 or even better 10 make more sense?!??
Another bit of basically useless information, unless you're into testing meters! lol.
Rob
P.S. Stuff like this is absolutely fascinating to me. I just HAVE to know not only how it works, but also why it works.
Old 04-11-2010, 08:14 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Old 04-11-2010, 09:00 AM   #9
Rewards Points: 1,192
bobelectric is offline   Reply With Quote
Old 04-11-2010, 09:45 AM   #10
fabrk8r
fabrk8r's Avatar
fabrk8r is offline   Reply With Quote
Old 04-11-2010, 10:10 AM   #11
Originally Posted by Speedy Petey View Post
08487
I said 08487 because it is 3/4 between 6&7 so I rounded up.
How about 08486.75 ?
Old 04-11-2010, 12:55 PM   #12
Apostle is offline   Reply With Quote
Old 04-11-2010, 02:01 PM   #13
nap
You talking to me?
nap's Avatar
I think it's closer to 8486.625
and why would you round up? the entire accurate reading is based on not rounding up but taking the lesser number. Although there is no dial further that would define the last number as 6 and not 7, continuity of method would cause the last dial to be read as 6.
Old 04-11-2010, 05:49 PM   #14
I voted "none of the above",, I watched that meter for the last hour,, its not moving, it can't be "reading" anything.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 04-11-2010, 06:28 PM   #15
joed's Avatar
Rewards Points: 11,516
You would be billed a 8486.
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Electric meter garyoutwest Electrical 1 10-02-2009 05:10 AM
Ballpark cost to to move electric meter 99miles Electrical 2 09-29-2009 09:37 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 09:34 AM
Does it matter how close your panel is to your meter? jamiedolan Electrical 10 10-18-2008 05:38 AM
