Can You Put A Switch On Low-voltage Lighting? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 11:16 AM   #1
Can you put a switch on low-voltage lighting?
I just installed low-voltage lighting on the stairs of my deck. They are wired to a 200w transformer with a timer, but it's on the ground level. I would like to get rid of the timer and wire a switch for the deck on the second level. I can't find anything on if this is even possible. Everything I have seen talks about regular light circuits, I am assuming there is a difference? Thanks for the help!
Casey12081 is offline   Reply With Quote
Old 08-07-2009, 11:27 AM   #2
You will still need the timer for the transformer but you could:
A) Leave it turned on and switch the recep that it is plugged into
B) Leave it turned on and install a switch on the LV side.
220/221 is offline   Reply With Quote
Old 08-07-2009, 12:27 PM   #3
if the clock is removable or can be disconnected ....you can do it.
yes you can put a regular switch on a low voltage wire.
normal switch is rated up to 277v, you'll be dealing with 13 volts probably.... you're good to go
ChristopherSprks is offline   Reply With Quote
3-way illuminated switch - voltage present ktulu05 Electrical 18 11-29-2009 04:01 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Low voltage at switch, unsure what switch is for amdspitfire Electrical 14 11-23-2008 08:54 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
