Can You Please Tell Me Which Wires Are Which? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 05:24 PM   #1
Can you please tell me which wires are which?
Here is a diagram of my wall outlet....
Can you please tell which wires are which? I am guessing that the black wires are the "line" and "load", and the white wires are "neutral", and the exposed gold wiring in the middle is "ground". Am I correct?
mike932 is offline   Reply With Quote
Old 05-12-2011, 06:13 PM   #2
Electrical Contractor
kbsparky's Avatar
Black wires in the large wire-nut would be "Line"
Blue wire from the (timer?) is "load"
Lone red wire on one of the switches is also a "load"
Lone black wire on other switch is also a "load"
White wires are "neutral"
Bare wires are "Ground"
-KB
Old 05-12-2011, 06:16 PM   #3
Thanks sparky. The light switches are not grounded. Should they be?
Old 05-12-2011, 06:17 PM   #4
Master Electrician
Rewards Points: 3,916
The bare copper wires are the equipment grounding conductors. The white wires are the grounded conductors commonly called the neutrals. The black wires connected to the red wire nut are the hots or line side if your prefer. They provide power to the switches which in turn supply power to the devices or luminaires when the switch is in the on position.
brric is offline   Reply With Quote
Old 05-12-2011, 06:18 PM   #5
Master Electrician
Damn...........you are quick.
Old 05-12-2011, 06:20 PM   #6
How do I connect a ground wire to the copper thing in the middle? Just wrap a flexible wire around the copper and twist it?
Old 05-12-2011, 07:03 PM   #7
kbsparky's Avatar
I let that post sit for over hour before tackling it. Slow, if you ask me ..
-KB
Old 05-12-2011, 07:09 PM   #8
kbsparky's Avatar
You need to use a proper pressure-type connector, such as a wire-nut, or another crimp sleeve. You may have to remove the present crimp in order to access enough bare conductor to properly add one. A long tail could be utilized to ground all your switches by looping from one to the next.
I noticed your switches are not the grounding type. I would recommend that you consider replacing them both with grounding type. The ones that have a green screw terminal on one side.
-KB
Old 05-12-2011, 07:22 PM   #9
Thanks again. My house is 10 years old. Looks like the electrician did a cheap job.
Old 05-12-2011, 08:26 PM   #10
Just found another helpful site.... http://www.lowes.com/cd_Do+Simple+El...cts_193125234_
Old 05-12-2011, 09:19 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
HAHAHA
If you say so.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Thurman (05-13-2011)
Old 05-12-2011, 09:36 PM   #12
Speedy's not very friendly, is he?
Old 05-13-2011, 12:01 AM   #13
Scared Electrician
Saturday Cowboy's Avatar
no he's just kindly pointing out that, that site and those like it do more harm than good.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Saturday Cowboy For This Useful Post:
mike932 (05-13-2011), Speedy Petey (05-13-2011)
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
