Can You Place An Electrical Outlet Inside Pole Wrap. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 07:03 PM   #1
Can you place an electrical outlet inside pole wrap.
I am finishing a basement and was wondering if anyone has used pole wrap to wrap there support pole in the basement. And also put an electrical outlet in it? is this possible. Is there code against it?
luweee is offline   Reply With Quote
Old 03-15-2009, 07:16 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I'm in California
What's a Pole Wrap?
I already figured out what a basement must be.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-15-2009, 09:39 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,888
I don't know if "pole wrap" is a common term or a commercial product, but I see no reason not to have a receptacle in a column.
Old 03-15-2009, 09:45 PM   #4
He wants to frame and wrap the pole with drywall. A recep in there is a good idea. Keep the cable at least 1 1/4" away from the drywall.
220/221 is offline   Reply With Quote
Old 03-15-2009, 11:33 PM   #5
Will I have to frame it to do this or can I use the Commercial named pole wrap. I dont wan this to be a squared bottom. I keep stubbing my toes on the one in my upstairs family room.
Old 03-15-2009, 11:37 PM   #6
DIYer
Pole wrap doesn't have enough room for a flush outlet.
You can of course put a surface mount outlet in a metal box with a metal conduit sleeve... If you can get a screw into the pole wrap solidly enough to secure everything.
But that's going to be kind of ugly and defeat the purpose of pole wrap in the first place.
And don't get any bright ideas about cutting holes in your basement poles... You'll compromise their strength.
Gigs is offline   Reply With Quote
Old 03-16-2009, 12:16 AM   #7
Thanks for your input GIGS. Yeah I wouldn't even think about cutting the pole. I'm an engineer and I know that would not be good!!!!!!!!!!
Thanks again gigs.
Looks like I will have to frame it.
Old 03-16-2009, 12:34 AM   #8
Tom Struble's Avatar
Rewards Points: 2,002
you could attach a mounting block made out of wood that has the contour of the post on the back and is flat on the front for the outlet
Tom Struble is offline   Reply With Quote
Old 03-16-2009, 09:19 AM   #9
Registered User
Termite's Avatar
I can tell you for sure that there's no code violation in doing this.
Old 03-16-2009, 01:50 PM   #10
Tool Geek
PaliBob's Avatar
Deleted Had suggested #91 Leviton Outlet but cannot be wired except from the back side
Can you place an electrical outlet inside pole wrap.-leviton-91-receptacle.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Electrical weirdness jheavner Electrical 27 10-09-2008 06:40 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Electrical Outlet Problem McRier Electrical 3 12-19-2005 01:33 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
moving an electrical outlet bobo Electrical 4 05-21-2005 01:15 PM
