Can You Override Outdoor Lights On A Timer W A Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 02:30 PM   #1
Rewards Points: 77
Can you override outdoor lights on a timer w a switch?
I recently wired and installed two outdoor post lights. I haven't wired them to a switch or panel yet, just ran wire thru basement walls. If I didn't want them on all night is there a way to override the timer with a switch if I wanted to turn them on or off independent of the timer? If so how would I do it?
Thanks in advance for any info
dbldee20 is offline   Reply With Quote
Old 11-08-2011, 03:45 PM   #2
Licensed electrician
Rewards Points: 1,772
You would install a switch downstream from the timer. If you install the switch upstream of the timer it would lose its time setting.
Old 11-08-2011, 05:36 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Wire a switch loop around the timer. One side on the hot input to the timer and the other on the switched hot output of the timer.
The timer will run normally but the switch will turn the lights on regardless of the timer.
Coastal South Carolina
timer switch wiring mlang43 Electrical 2 06-13-2011 02:09 PM
Is it possible to override IR sensor with single switch? torizus Electrical 5 03-13-2011 03:05 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 06:22 PM
fan timer on a switch loop someguy86 Electrical 3 08-02-2010 08:05 PM
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 06:32 AM
