Can You Mix 6 Volt And 12 Volt Batteries. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 09:47 PM   #1
Can you mix 6 volt and 12 volt batteries.
Can you mix 6 volt and 12 volt batteries on one bank?
hbnavarrete is offline   Reply With Quote
Old 02-24-2011, 10:37 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
In a bank, no. In a grocery store, yes.
what's the scoop? Explain what you are doing.
I know you can connect the in series. The voltage will be additive. I am thinking, but not sure, that you should not hook them up in parallel.
Old 02-24-2011, 10:59 PM   #3
Rewards Points: 338
no, you cannot connect batteries of different source voltages in parallel. if you do, the battery with the higher voltage will push current into the battery with lower voltage and something will get really hot or blow up. before something goes bad, you will get an output voltage equal to the lower of the two, in your case it would be 6 volts.
bottom line, don't do it.
NitroNate is offline   Reply With Quote
Old 02-24-2011, 11:49 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
It will technically work, but I think when it comes to charging, you'll run into issues, assuming this is something that will be charged. I would use all same voltage/type of batteries in one bank.
Old 02-25-2011, 12:45 AM   #5
Scared Electrician
Saturday Cowboy's Avatar
well the only thing you could do is a series/parallel combo circuit. if you don't know what that is take some time to read up on it.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-25-2011, 01:04 AM   #6
Wire Chewer
Rewards Points: 126
Oh yeah, you'd want to ensure each "cell" is same voltage.
Old 02-25-2011, 02:15 AM   #7
Scared Electrician
there would still be some problems tho, different Amp-hr ratings of the batteries for example would cause the current of the bank to fall off as small batteries drained quicker
Old 02-25-2011, 05:34 PM   #8
Wire Chewer
Rewards Points: 126
Yeah for sure, you'd want to match the amp hour, but even then, that's getting complicated. Do you want the 6 volt batteries to have same AH as the 12v ones, or should the two combined be the same? Or is it more complicated then that? Best to just stick to all the same batteries. :P
It will work, but how well, is another story.
Old 02-25-2011, 06:18 PM   #9
Electrical Contractor
kbsparky's Avatar
IF you need 18 Volts, go for it!
-KB
Ryobi batteries 14 vs 18 volt firepatch Building & Construction 1 12-16-2010 03:28 PM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
Cordless Drill Batteries MrBill_DIY Tools 11 01-15-2009 04:17 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
