Can You Mix 20 And 15-20 Circuit Breakers In Same Electrical Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 05:50 PM   #16
Licensed electrician
Rewards Points: 1,884
The tandems allow two circuits to fit in the space of one breaker slot.
Old 05-15-2013, 06:01 PM   #17
Special User
Rewards Points: 1,230
The "quad" allows one to add a 240V circuit to a full panel without losing two 120V circuits in the process. Or gain two 120V circuits from the space occupied by a 240V circuit.
Separate handle tied tandems can serve a MWBC, but typically not a 240V circuit because they would likely be independent trip, not common trip.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Toe kick electrical, which circuit? langless28 Electrical 4 10-17-2012 05:48 AM
Duplex circuit breakers wavewuver Electrical 9 12-17-2011 10:12 AM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Replacing circuit breakers with AFCI ozdiy Electrical 25 07-04-2010 08:09 PM
Need some electrical circuit advice dgbehrends Electrical 24 01-15-2009 11:57 AM
