Can You Mix 20 And 15-20 Circuit Breakers In Same Electrical Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 11:34 PM   #1
Can you mix 20 and 15-20 circuit breakers in same electrical box?
I need to replace several circuit breakers and just noticed that there are both "15-20" and "20-20" circuit breakers in the electrical box. Is that okay or do I need to make sure they are consistent? Thanks!
Texas Rose is offline   Reply With Quote
Old 05-15-2013, 12:41 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Just make sure the wires are on the correct size breaker. How they are arranged doesn't matter.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
micromind (05-15-2013)
Old 05-15-2013, 06:30 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Why do you need to replace breakers?
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Jim Port (05-15-2013), Speedy Petey (05-15-2013)
Old 05-15-2013, 07:41 AM   #4
Rewards Points: 3,130
OK, I'll bite. What is a 15-20 circuit breaker? I've never seen a breaker so labeled.
Old 05-15-2013, 07:45 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Square D Homeline
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-15-2013, 07:52 AM   #6
Licensed electrician
Rewards Points: 1,258
If you are thinking about upping the breaker because the circuit is tripping, please do not do it. You would be creating a fire hazard.
Breakers rarely go bad, so replacing one let alone a couple raises some eyebrows.
Philly Master (05-15-2013)
Old 05-15-2013, 07:59 AM   #7
Rewards Points: 150
having different size breakers is OK what you dont want is different brands as not all breakers are UL listed for different panels. If you are unsure it is best to match the breakers to the panel by manufacture
usair is offline   Reply With Quote
The Following User Says Thank You to usair For This Useful Post:
Old 05-15-2013, 11:00 AM   #8
Originally Posted by rjniles View Post
Square D Homeline
Well, I've never seen one of those. I learn something every time I come here.
Old 05-15-2013, 11:03 AM   #9
electures's Avatar
Sieman's has them as does a lot of other manufacturers.
Old 05-15-2013, 11:11 AM   #10
Special User
Rewards Points: 1,230
Square D makes some funky stuff, like this "Quad" 20-30-20 breaker:
Can  you mix 20 and 15-20 circuit breakers in same electrical box?-homeline_quad.jpg
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 05-15-2013, 12:11 PM   #11
k_buz's Avatar
All manufacturers that I know of make tandem breakers of just about any combo you would like.
Old 05-15-2013, 03:07 PM   #12
What's the advantage? Are they cheaper than two separate breakers in one slot?
Old 05-15-2013, 03:10 PM   #13
Special User
If anything, they're more expensive. The reason they make them is for people who's panel is full, but need to add more circuits. A tandem is cheaper than ripping out a whole panelboard and installing a bigger one.
It's better to just install a 40-space panel to begin with, and only fill it half full with full-size breakers at construction.
Old 05-15-2013, 05:17 PM   #14
k_buz's Avatar
Not all panels are rated for tandem breakers. And some panels that are, limit where you can locate the tandem on the buss.
Old 05-15-2013, 06:09 PM   #15
So what's the point of using them? Since they're cheaper, why not instead use two separate tandem breakers instead of the more expensive "combined" ones?
Toe kick electrical, which circuit? langless28 Electrical 4 10-17-2012 06:48 AM
Duplex circuit breakers wavewuver Electrical 9 12-17-2011 11:12 AM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Replacing circuit breakers with AFCI ozdiy Electrical 25 07-04-2010 09:09 PM
Need some electrical circuit advice dgbehrends Electrical 24 01-15-2009 12:57 PM
