Can You Just Upgrade The Interior Of The Load Center ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 03:11 PM   #1
Can you just upgrade the Interior of the Load Center ?
Wondering if an interior of the panelboard alone can be upgraded, provided that the newer panelboard box dimension, physically, is the same as the old one.
This way, there is no hassle of removing the panelbox pan and all existing wiring that was pulled into it, but just a simple swap of the interior.
I.e.)
Old Panelboard: Siemens G4040MB1200
New Panelboard: Siemens P4040B1200CU.
Of course the new cover panel/door from P4040B1200CU would have to be used in place of the cover/door from, G4040MB1200.
khfactor is offline   Reply With Quote
Old 12-23-2012, 03:46 PM   #2
Electrical Contractor
kbsparky's Avatar
Done that many times.
You will have to accurately locate the new guts and drill out mounting holes as needed.
You'll also probably have to drill new cover holes as well.
-KB
Old 12-26-2012, 05:36 PM   #3
Thanks, I thought it was do-able. Since my existing Load Center "can" is already recessed into the wall, I did not want to remove the "can" only to be replaced with the same size can.
I want to keep the existing can and just upgrade the gut. Well, it turned out that my existing G4040MB1200 Load Center can is 39" long and the newer model of the Siemens Load Center P4040B1200 is 36" long.
Not wanting to give up, I do some more researching in the Siemens catalog and I found the Siemens Load Center P4260B1225CU that has the 42 space and for 60 breakers which is the same length (39") as my old Load Center. Bingo !!!
I do hope that it is OK to mount the NEW interior 42 slot/60 breakers into my existing "can" which was built for only 40 slot/40 breaker interior. Overall length of both CANs are the same 39".
If it is OK, then I am hoping that it is just that; drilling a couple of holes in the existing can to accommodate the new P4260B1225 Load Center interior. I can use the NEW cover and the new door that came with the box.
By the way, is this something a DIY person can do or do I need to hire an electrician? I assume the meter has to be taken out of the socket to do this work....
Siemens Load Center Help - Bonding aquasport17 Electrical 4 10-24-2012 11:21 AM
Main load center grounding question. sgip2000 Electrical 18 10-03-2012 11:45 AM
Boxing In My Load Center? ddawg16 Building & Construction 5 08-22-2012 10:21 PM
What is this piece of metal for in my load center? danielrg Electrical 6 05-23-2012 01:09 AM
Minimum distance from ground for load center. The Mindz i Electrical 52 03-15-2011 11:46 PM
