Can You Drill Load Center? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 11:44 AM   #16
Electrician
SD515's Avatar
Rewards Points: 504
The ‘pigtails’ are not compliant. A lug should be added to each bar to accommodate the larger wires.
Kyle
Old 02-24-2012, 11:58 AM   #17
Rewards Points: 214
Originally Posted by Jim Port View Post
Splitting the conductors as shown in the pic is not the correct method. An adapter lug should be used.
Thanks Jim,
Can you reference an adapter lug for me that would work on this panel? The panel is missing the label so I cannot reference anything. Also, there is the main lug at the top on the left neutral/ground bar. If I keep the panel, can I use that for one of the wires if it will reach of course?
Ralph
Ralph III is offline   Reply With Quote
Old 02-24-2012, 12:11 PM   #18
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
That one is one 150 amps I was sure at one time you said you had 200 amps.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-24-2012, 12:24 PM   #19
Rewards Points: 214
Hey rrolleston;
The copper wires feeding our outdoor main load center(from the meter) are 2/0. That is good for 175amps (@ 75 deg) as my cheat sheet says. Someone else stated it actually is good for 200amps?
I had an POCO rep tell me several years ago, when I simply inquired about our service, and she stated we had 100amp. She may have mistakenly referenced our shop though?
I just confirmed we do indeed have 200amp service to our house. Thanks for bringing that to my attention! You saved me some time in researching what to use....
Ralph
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
