Old 10-04-2012, 04:51 PM   #1
Can you connect 10-3 southwire to 12-2
I was mislead by a friend and bought 50 feet of 10-3 Southwire outdoor burial cable. I needed to buy 10-2.
I have 4 outdoor outlets that run off a 15 amp breaker. I want to install a fifth outlet at the end of my driveway that is 25 feet away. Can I connect the 10-3 to the existing outlet that has 10-2 and run the new outlet to the end I my driveway.
I tried to return the 10-3 to get more 10-2 but I can't find the receipt. I'm I going to have to buy 10-2.
Ncs0816 is offline   Reply With Quote
Old 10-04-2012, 04:54 PM   #2
I know the 10-2 has a black, white, and ground cable. And the 10-3 has two blacks, white and ground. Could I just put a wire cap nut around one of the black wires and use the 10-3. Or am I stuck with this 10-3. Am I going to have to buy more 10-2?
Old 10-04-2012, 05:13 PM   #3
A "Handy Husband"
rjniles's Avatar
If it is 10/3 UF cable, it has a red, a black, a white and a bare ground. You can use it in lieu of 10/2 and cap off the red conductor.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-04-2012, 05:31 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
WHY #10 for such a shot run on a 15A breaker????
Old 10-04-2012, 06:29 PM   #5
I don't know. I didn't build the house
Old 10-04-2012, 07:51 PM   #6
Thanks that's what I wanted to know
Old 10-05-2012, 08:10 AM   #7
Did you buy the 10/3 at a big box store like Home Depot or Lowe's? If so, you can return it without a receipt - you'll get a store credit instead of your money back. Buy some 12/2 UF
Old 10-05-2012, 11:09 AM   #8
I tried that. But because I returned something last week without a reciept they said I have to wait 90 days until my next return
Old 10-05-2012, 11:23 AM   #9
So send your wife, brother, friend, a bum off the street (give him $5).
Trane is offline   Reply With Quote
The Following User Says Thank You to Trane For This Useful Post:
sublime2 (10-05-2012)
Old 10-05-2012, 11:41 AM   #10
Really?? I've never had that problem at my local stores. But, then, I've spent over $50K at Home Depot in the last two years while building my own house. I'm on first-name basis with all the managers.
Old 10-05-2012, 02:06 PM   #11
I tried that to. My brother went up there. Turned down. The system must know that we are brothers.
Old 10-05-2012, 02:37 PM   #12
No, it doesn't know that you are brothers. This is the silliest story I ever heard.
mpoulton (10-05-2012)
Old 10-05-2012, 02:39 PM   #13
I tried complaining. I told them I do tons of business with you. Yada yada. They said no. I'm getting tired of home depot
Old 10-05-2012, 10:07 PM   #14
I've returned dozens of items at HD,often several times in one day. NEVER had any problem. Talk with the managers? Has anyone else had trouble with returns at HD? I even bought something in NC and returned it in OR. No problem though I did have the receipt. In fact, if you charged the original purchase to a credit card, HD couldn;t care less whether you have a receipt. Good luck!
philS is offline   Reply With Quote
Old 10-05-2012, 10:13 PM   #15
DIY Enthusiast
sublime2's Avatar
Ditto!!
sublime2 is offline   Reply With Quote
Combine 7' garage doors into one 16+ ft door - connect brick lintels Irestone Concrete, Stone & Masonry 12 03-22-2012 04:51 PM
Apartment- Connect portable washer straight to sink drain + double quick connect? DrDreams Plumbing 1 03-14-2012 09:30 AM
What pipe is this? can I connect abs to it? oregondiy Plumbing 3 04-04-2011 08:33 AM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 11:13 AM
Adding a phone line to an older connect point cramsmith General Discussion 3 11-23-2005 12:35 PM
