Old 08-29-2009, 09:15 PM   #1
Can you change a 220v plug on a dryer
I just bought a dryer and I was wondering if I could just change the type of plug it has. It has a three prong 220v and my apartment is just wired for 110v plugs. Can you help or should I just get a new dryer.
clueless_03 is offline   Reply With Quote
Old 08-29-2009, 09:20 PM   #2
Remodeler
adpanko's Avatar
No, you can't just put on a new plug. The dryer requires 220v, so you NEED a 220v outlet to plug it into. If you didn't already have an electric dryer in that same spot, you'll need to run a new 220v outlet. There is no other way. 110v dryers don't exist, at least not that I'm aware of. Gas dryers have a normal 110v plug, but that just controls the timer and light basically, it doesn't actually provide the drying, the gas does. But if you have a pure (ie not gas) electrical dryer, you need a 220v outlet.
adpanko is offline   Reply With Quote
Old 08-29-2009, 09:27 PM   #3
Xtreme DIY'r
Dryers also usually require a 30a 240v breaker & #10 wire
Household outlets are #12 wire (20a only), so you couldn't even convert a dedicated #12 run/outlet to 240v
And now you need a 4 prong cord is my understanding
--2 hots, neutral & ground
Old 08-29-2009, 09:43 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Household outlets are #12 wire, soyou couldn't even convert a dedicated #12 run/outlet to 240v
Well, this is a bit misleading, but the sentiment is accurate.
Standard receptacles are 120v, 15 or 20A. An electric dryer requires a 120/240v, 4-wire, 30A circuit. The two are not even close to the same.
Edit: Sorry, the misleading part is that a dedicated 15 or 20A line can be changed to a 15 or 20A straight 240v circuit. It is true that it CANNOT be changed to a 120/240v, 4-wire circuit.
Old 08-29-2009, 09:49 PM   #5
Floor Sweeper
The apartment must have had a gas dryer before. Bummer, I guess you'll have to get another gas model.
I would have looked before I went shopping.
junkcollector is offline   Reply With Quote
Old 08-29-2009, 10:25 PM   #6
Wire Chewer
Red Squirrel's Avatar
Should not be too hard to run a new plug. Should be one of these:
The two straight blades are the hots, they make 240 volts (normally red and black, order does not matter), the top middle is the ground (normally bare) and the botton is the neutral (normally white). From neutral to any of the hots it is 120 - these are normally the terminals on a 120v plug (the two hots alternate throughout the house) but in the case of a dryer and stove both 120 and 240 are needed so this is the plug you need. (a stove one is slightly different as it is 40 amps I think... dryer is 30)
And you will need #10 wire for this. In that pic it is #10, and as you can see it's quite thick (and more expensive).
Red Squirrel is online now   Reply With Quote
Old 08-30-2009, 02:39 AM   #7
Thank you for the information
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 06:45 PM
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 02:07 PM
Running new dryer wire...but dryer is three plug currently. RyanD Electrical 7 08-07-2009 03:33 PM
dryer Outlet change 3 prong to 4 prong oldpirate General Discussion 2 08-06-2008 07:18 PM
