Can You Attach Ceiling Fan To Joist? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 09:46 PM   #16
Licensed electrician
Rewards Points: 1,616
On espisodes of this old house they have installed wiring not to code like the pendant lights with two cables into a pancake box.
Plastic fan box are fine. There is a metal plate above the box that the screws thread into. As someone else said the box is only holding the splice, the weight is on the bracket.
Old 09-08-2012, 09:50 PM   #17
Originally Posted by gregzoll View Post
Again, no I would not use it. And no those are not larger lag screws. And Yes, I have seen a fan pull one out of a joist.
Those lags are larger, IIRC they are around a 1/4" or 5/16" lag about 2" long. Plenty of support for a fan.
jbfan (09-09-2012)
Ceiling joist Redbeard58 Building & Construction 3 07-03-2011 08:09 PM
4 lights finished ceiling wire through joist?? qchawkfan Electrical 15 01-25-2010 09:39 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
