Can You Attach Ceiling Fan To Joist? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 12:30 PM   #1
Can you attach ceiling fan to joist?
I laid out installation of four new recessed can lights and a ceiling fan in the middle. Installed can lights and when I went to cut the hole for the ceiling fan I was lined up right on a joist. Rather than moving it to the side 6 inches and making it asymmetrical, is there a way to attach the fans directly to the joist?
maxman10 is offline   Reply With Quote
Old 09-08-2012, 12:35 PM   #2
Rewards Points: 6,652
Why not move it so that you can place a fan box between the joists. Really is not going to matter if it is six inches to the right or left.
Old 09-08-2012, 12:38 PM   #3
I will I have to. Just wondering if there's a common way to put it straight on the joist
Old 09-08-2012, 12:51 PM   #4
try this
this may work for what you want to do.
http://www.lowes.com/pd_19841-53911-CFB-12_4294722500__?productId=3819941&Ns=p_product_qty _sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_ qty_sales_dollar|1&facetInfo=
drwheels is offline   Reply With Quote
Old 09-08-2012, 01:18 PM   #5
drwheels, good for a lighting fixture, not good for a ceiling fan.
Old 09-08-2012, 01:25 PM   #6
Sparky
Rewards Points: 510
That is a fan rated box. The Screw for the fan bracket go directly in to the joist/rafter
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
jbfan (09-08-2012), stickboy1375 (09-08-2012)
Old 09-08-2012, 02:15 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
greg, before you speak out of turn, you may want to know what you're talking about first.
With that said, you could use a regular box and fasten the fan to the structure.... both are acceptable.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Techy (09-08-2012)
Old 09-08-2012, 02:16 PM   #8
E2 Electrician
Sure, just use a pancake box, either fan rated or regular, if you use a regular pancake box, make sure you secure the fan bracket to the joist.
Old 09-08-2012, 02:27 PM   #9
Electrical Contractor
kbsparky's Avatar
You don't have any CLUE what you are talking about. That box is specifically made for ceiling fan mounting, complete with larger lag-screws that fasten the fan directly into the joist.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
jbfan (09-09-2012), stickboy1375 (09-08-2012), Techy (09-08-2012)
Old 09-08-2012, 02:38 PM   #10
These work great. I have used this style before. And it is rated for fan, the spec's show 70lbs weight limit, which makes it a fan box.
parman is offline   Reply With Quote
Old 09-08-2012, 02:40 PM   #11
E2 Electrician
Or use this if your hole is not perfectly centered on the joist.
Old 09-08-2012, 05:09 PM   #12
Again, no I would not use it. And no those are not larger lag screws. And Yes, I have seen a fan pull one out of a joist.
Old 09-08-2012, 05:54 PM   #13
Insatiable Learner
Rewards Points: 166
Post
Every application is different. The reason why I would never use this for a fan (even if it is supposedly rated for one) is because it's made out of plastic. I have seen too many plastic boxes/fan nightmares. I was talking with a master electrician for This Old House and he has seen the same, and also will not use plastic boxes with heavy ceiling lights or fans. They are fine when they are new, but after the fan has some wear and tear on it and it gets more and more out of balance it is too much stress for the plastic - and the boxes crack and then break. I'm sure someone must make something like this out of metal though. In fact I'm going to look for one because I might need one for an upcoming project. Being plastic I would only feel safe using something like this if the light/fan was 35 pounds or less. I've seen too many break for it to be a coincidence, and fans are a lot more expensive than a five dollar plastic box, not to mention the possible safety issues. I like Stickboys shallow box option much more.
Just found this one. Look at number 77706. It could hold your mother-in-law (I kid)
It mounts to directly to the joist from the SIDES not the bottom (and it's metal)
Last edited by AngelArs; 09-08-2012 at 06:07 PM. Reason: Saw stickboy1375 shallow box option
AngelArs is offline   Reply With Quote
Old 09-08-2012, 06:07 PM   #14
I think what you might fail to understand is for this type of box or the ones I have used in the past, the box does not support the fan. The box contains the wires. The lag screws are used to screw the fan bracket into the bottom of a joist. This simple combination of electrical box and fan support is quite nice and easy to work with. I would not use the 8-32 screw holes from a plastic box to support a fan bracket. That is not how they are designed.
I don't know about you, but a fan bracket screwed into the bottom of a joist is pretty darn sturdy.
BTW, if you compared the plastic box mounting directions with the metal one you like, you might find they are very similar.
Old 09-08-2012, 06:14 PM   #15
Insatiable Learner
Rewards Points: 166
Everything's relative I've seen those screws left in the joist and the plastic broken box laying on the ground before.
I would think four bolts on the side of the joist (like with number 77706) would out support a bottom joist mounting when it comes to something heavy that's spinning.... There were other mounts in that catalog that would also work better than a plastic box. Personal preference.
I'm not so concerned with how they mount, I'm concerned with what they are made out of. I've never seen a metal box break, ever. I've seen plastic ones break though.
Ceiling joist Redbeard58 Building & Construction 3 07-03-2011 09:09 PM
4 lights finished ceiling wire through joist?? qchawkfan Electrical 15 01-25-2010 10:39 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
