Old 06-20-2012, 11:11 PM   #1
Can you add torsion springs to a Progress P87 recessed light
Is there a way to retrofit a Progress P87 recessed light so that it can use a trim kit with torsion springs?
I want to install a AllPro LED retrofit kit and it would be a lot easy if my recessed light had torsion spring receivers but the Progress cans don' t them. Maybe I can buy a part to add to the can???
jillechie is offline   Reply With Quote
Old 06-21-2012, 07:24 AM   #2
Electrical Contractor
kbsparky's Avatar
I've installed a couple of TEK screws to make those retro-fit trims work.
If you happen to find someone who sells the bracket that is usually associated with those trims, please let me know. I believe that Sylvania is working on providing a kit for use with their LED trims, but don't know if they are available for purchase as of this time.
-KB
Old 06-21-2012, 07:28 AM   #3
Licensed Electrician
k_buz's Avatar
Can you post a picture of what you are working with? Maybe you don't have the friction clips installed correctly.
Location...Location...Location
confusion with track light stephenbishop Electrical 7 03-10-2012 02:37 PM
Recessed Can light making noise Kenny101 Electrical 6 02-28-2012 12:25 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 01:21 AM
Recessed light directly over shower adpanko Electrical 33 09-16-2009 07:56 AM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
