Can Wire Attenuate ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 10:14 AM   #1
Rewards Points: 1,062
Question
can wire attenuate ?
i was wondering if it is possible to attenuate wire while threading it forcefully through tight beam holes.
i had to run a 6/3 cable along the entire depth of my basement, i.e. about 70 ft. i drilled 7/8 speedbore holes using my right-angle drill (god, do i love that tool !) but then decided to also run a 12/2 cable through it as well. the holes were sufficient for the 6/3 but the 12/2 fit in real snug and it was tight pulling it through. since i had to pull real had, i was worried whether that could have cause attenuation of the wire, since it wasn't sliding smoothly ?
i was also wondering if twisting of the wire while threading can cause breakage or any other issues ? the 6/3 was twisting like crazy and there didn't seem to be a way around it, unless someone unrolled the entire spool down the street so i was pulling a straightened cable.
Old 12-15-2008, 10:34 AM   #2
Rewards Points: 174
If the holes were to small for the extra 12/2, you should have drilled new holes. Your cables are probably okay. It's pretty tough stuff.
Old 12-15-2008, 10:36 AM   #3
thanks. the reasons for not drilling new holes were beam conservation and laziness.
Old 12-15-2008, 11:41 AM   #4
In new construction, conforming to codes, this may not get you far with the inspector, but its safe.
rgsgww is offline   Reply With Quote
Old 12-15-2008, 11:42 AM   #5
Question
are you referring to beam holes ?
Old 12-15-2008, 01:36 PM   #6
You mean work-hardening?
Old 12-15-2008, 02:26 PM   #7
Yeah, there's code about de-rating the ampacity of the circuit. I don't think its an issue though.
Old 12-15-2008, 08:12 PM   #8
DIYer
12/2 can derate a lot and still be 20amp, it's got a built in overrate.. so you rarely have to worry about derating it lower than 20a
Gigs is offline   Reply With Quote
Old 12-15-2008, 08:31 PM   #9
Rewards Points: 1,514
You might tear the cable jacket or even the insulation on one or more conductors. Then it technically does not meet code.
Old 12-16-2008, 09:39 AM   #10
not sure what you mean.
Old 12-16-2008, 10:58 AM   #11
Rewards Points: 174
You are correct. It's called bundling. But this is not a case of bundling. The beams are not thick enough to even consider it.
Old 12-16-2008, 11:26 AM   #12
Yeah, I know about bundling. I thought there was something about how many wires through holes,etc.
Old 12-16-2008, 01:04 PM   #13
If you bend metal back and forth, or stretch it, it becomes harder, more brittle.
http://www.google.com/search?hl=en&q...=%22work+hardn
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
