Can Tandem Breakers Be Added? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2015, 02:03 PM   #1
Rewards Points: 14
can tandem breakers be added?
Hi all, wondering if this load center is rated for tandem breakers. How would one tell? It's a ch4 series e, but can't find any specs on it. Wanting to add a couple of extra circuits.
can tandem breakers be added?-img_20150213_160147245_top_1423943731825.jpg   can tandem breakers be added?-img_20150213_160207892_1423943820364.jpg
osage is offline   Reply With Quote
Old 02-14-2015, 03:49 PM   #2
Electrician
Rewards Points: 2,882
Id be more concerned about the code violations.
Jump-start is online now   Reply With Quote
Old 02-14-2015, 04:10 PM   #3
Rewards Points: 1,414
Not real helpful to the guy. Maybe tell him what the issue instead of having him guess. Ron
ront02769 is online now   Reply With Quote
Old 02-14-2015, 04:14 PM   #4
Rewards Points: 14
Just bought this little house, the box was wired this way.. There's combination of old 2 wire with no ground and new Romex with loose grounds. What's the best way to get this cleaned up? I know a new service is best, but can this panel be saved? or is it obsolete not having a ground bus w/the romex?
Old 02-14-2015, 04:17 PM   #5
Electrician
How is continuing code violations helpful? Ok, I tell him to stick in a tandem, how is the hazard going to be corrected?
Old 02-14-2015, 04:20 PM   #6
Electrician
Glad you asked
Your panel will need a ground bar, and if the panel is grounded through conduit the neutral bonding jumper screw will need to be removed.
If you can't find a ground bar for a Cutler Hammer panel this age your best bet is replacing. Small panels like this are cheap at home centers.
Also, is this attached to the house or separate (detached)?
Old 02-14-2015, 04:33 PM   #7
Rewards Points: 470
*The labeling inside the panel should tell you how many circuits it can have. It is possible that is a 4/8 panel. 4 spaces/8 circuits. However if you have over 6 circuits you will need a main circuit breaker. Is there a main breaker or fused switch protecting this panel or is it straight off the meter?
I do not see a grounding electrode conductor which would need to be connected to the water pipe or a ground rod or both. That needs to be added as well as a ground bar to land those bare grounds onto. If this panel is fed straight from the meter, the neutral and grounds go on the same bar. If there is a main, the grounds and neutrals stay separate and the grounding electrode conductor should be in the main enclosure.
One thing, this panel seems to only have 120 volts. The one big black wire seems to connect to both bus bars. If this is the case, then I vote for a new service.
I would ask to see pictures of the meter and service, but I'm thinking they will just convince that this house is way overdue for an electrical upgrade.
I suggest that you call an electrical contractor and ask him or her what your options are.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
The Following User Says Thank You to MrElectricianTV For This Useful Post:
Jump-start (02-14-2015)
Old 02-14-2015, 04:35 PM   #8
Rewards Points: 58
Eaton has a CHT1515 or CHT2020 tandem breaker. Do a Google search to find a source. Seen some on Amazon around $27.50 free shipping.
Can't say for sure if they'll fit in that panel but they do make the tandems.
sparky48 is offline   Reply With Quote
Old 02-14-2015, 04:37 PM   #9
Electrician
Mr. Electrician TV said it better than me. :D
Depending is this is an attached or detached structure a lot changes.
An attached structure does not need a main or 6 or less throws if the enclosure is listed as 'service equipment'
A detached structure needs a disconnecting means like described above as well as ground rods.
The feed to this also makes me wonder how and what is going on. I see only 2 wires, and Im guessing metal conduit feeds the panel which acts a s a ground but that's just a guess.
The Following User Says Thank You to Jump-start For This Useful Post:
MrElectricianTV (02-14-2015)
Old 02-14-2015, 04:41 PM   #10
Rewards Points: 14
Sparky, did find some tandem breakers but wondering about code.
Yes attached to the house.
There's no main breaker or switch.
The panel is fed directly from the meter.
Yes only 120v
The ground drops from under the meter in conduit to a rod.
Old 02-14-2015, 04:46 PM   #11
Rewards Points: 470
Yes only 120v
Time to bring this house into the 21st century.
John Grabowski
MrElectrician.TV
Old 02-14-2015, 04:57 PM   #12
Electrician
Yes only 120v
Wait, the meter directly feeds this subpanel? Than what feeds your home panel?
Old 02-14-2015, 05:02 PM   #13
Rewards Points: 14
This is the main panel
Old 02-14-2015, 05:05 PM   #14
Electrician
OOHHH! My mistake!
I thought this was a subpanel fed from the main panel.
Ok, so this is your home panel then.
Ok, I agree with Mr. Electrician TV, if you can bite the money than a 21st century service upgrade is a smart investment.
Old 02-14-2015, 05:16 PM   #15
Rewards Points: 14
I totally agree a new service is best but money is tight.. what would you do to get by for a year or two with code/safety in mind? I'd like to add some circuits for the kitchen (dedicated circuits for a microwave, fridge, washer machine) The house is small 2bed/1bath, aprox 900 ft2. Not a lot of load.
15A breakers to 20A with pics SS283Convertibl Electrical 7 01-08-2014 11:30 PM
Breakers above 2 meteres high above floor av-geek Electrical 47 07-20-2013 07:39 AM
how do you know you can use tandem breakers? n175h Electrical 5 12-17-2011 10:35 AM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
SQUARE D TANDEM 15A SP Breakers 57_Hemi Electrical 6 07-30-2010 11:02 PM
