Can Someone Tell Me If Ge Makes This? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 07:48 PM   #1
can someone tell me if ge makes this?
I need duplex
15 and 20 amp breakers. The ones that act like 2 independent breakers and fill the space of 1 standard breaker. Thank you
brokenhammer is offline   Reply With Quote
Old 03-14-2011, 08:35 PM   #2
Journeyman Wireman
Rewards Points: 150
Yes, GE does make a twin (tandem) breaker. But you need to look in your panel and see if the buss will accept a tandem. Sometimes the schematic (panel label) will indicate if you can use them in a particular panel.
Jupe Blue is offline   Reply With Quote
Old 03-15-2011, 04:52 AM   #3
" Euro " electrician
frenchelectrican's Avatar
As Jupebleu tell ya on that part the main thing is you look up the model number of the load centré to make sure they can take the duplex breaker and pay attetion the bussbar tabs when you land the breaker.
That is reltive common item I know GE do carry them I think they are about 10 to 15 Euros.
Merci.
Marc
Old 03-15-2011, 06:01 AM   #4
No they don't make a combo 15 and 20, either 15/15 or 20/20.
http://products.geindustrial.com/Ind...&ONLINESTORE=N
If your panel will hold Half-width breakers, you can get these,
Do It Right is offline   Reply With Quote
House makes loud popping sounds at night michboddy Building & Construction 25 01-20-2015 04:17 PM
Ruud furnace makes loud boom starting up ruud HVAC 5 01-16-2011 10:16 PM
Sears Drill Press makes flash sclaggett Tools 2 12-28-2010 01:12 PM
Who makes the best refrigerators? Marlin Appliances 9 10-30-2007 06:36 PM
Ice Maker makes Blocks of ice Rick Bruner Appliances 1 08-30-2007 11:26 AM
