Can Someone Identify This Component? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 04:54 PM   #1
Question
Can someone identify this component?
I apologize if this is painfully obvious and also if this isn't the forum for a question like this, but I wanted to get some feedback before I invest in an electrician. This has been hiding under a faux AC vent in my kitchen forever and I was about to patch the wall right over it. The house was built in 1959 in west central Florida. I have no idea if it's hot or not and am looking for some info on what exactly it is and what purpose it serves before I go poking at it.
michaeld is offline   Reply With Quote
Old 02-21-2011, 04:59 PM   #2
Rewards Points: 720
It's a doorbell chime. The two vertical bars on the sides make the noise. There are two horizontal plungers that hit the bars. The terminals are: Common, Transformer, Front and Rear. Using the front terminal gives a double chime. The rear, just one. You could drywall over it, but it would be better to mount a surface chime and have a working doorbell. Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
michaeld (02-21-2011)
Old 02-21-2011, 05:09 PM   #3
Rewards Points: 530
Don't think so. I would assume it has to be accessible like any other live wiring; even though, it is low voltage.
Why would anyone want to close it in with dw? What if it needed repaired or replaced.
When I first bought this house it had a chime on the wall. I guess sit was from the 50's. It was brass, sure wish I had left it alone. I think it may have just needed a transformer. I knew little to nothing about those kind of things then and removed it. Kept in a building for a few years, and it got ...gone.
Old 02-21-2011, 05:13 PM   #4
Wow, well that certainly solves a few mysteries! 1. Why I've never been able to figure out where the bell sound has been coming from (not that I've tried very hard) and 2. why I only get one chime.
I think I assumed it was something more ominous because of it's location in the kitchen. Thanks for the info. I'll likely either mount a surface chime or find something aesthetic to cover it.
Old 02-21-2011, 05:14 PM   #5
Rewards Points: 720
Nobody said it was live. If it is, then yes, you need to disconnect it before abandoning it.
Mark
Old 02-21-2011, 07:21 PM   #6
Rewards Points: 530
Mark
Hmm, my bad. I choose to err on the side of caution.
Guewss I should have said if live.
So, can you legally just disconnect and stuff back in wall and cover them up?
Component Video to S-Video Schematics? Progen Home Theater 3 04-06-2010 01:01 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Trying to identify heat pump component icbidi HVAC 8 01-16-2010 05:57 PM
Want to make a simple audio component rack, need advice J187 Carpentry 14 01-06-2009 09:56 AM
Need help evaluating estimate- labor component ajm_ct HVAC 7 12-30-2008 05:42 PM
