Old 08-18-2011, 11:34 AM   #1
Share |
Can someone ID these old (60's era) breakers?
I would like to know if someone can identify these old breakers (brand, type etc.)
Also, is this type totally obsolete or could I swap modern ones in the same box? (i.e., avoid having to install new panel).
tobor8man is offline   Reply With Quote
Old 08-18-2011, 12:02 PM   #2
I=E/R
a7ecorsair's Avatar
Your panel box should have a manufactures label but you may need to remove the front cover.
a7ecorsair is offline   Reply With Quote
Old 08-18-2011, 04:50 PM   #3
some companies make breakers that will fit in old panels and some don;t. First step would be to identify what you currently have. There's usually a brand marked on the breaker, alot of the time on the bottom of it where its not visible from the front. You could take one out and look for a label if you feel comfortable doing so. Be sure to turn off your main breaker before removing the breaker.
MitNotrof is offline   Reply With Quote
Old 08-18-2011, 05:20 PM   #4
Thanks all. I will remove the cover (after shutting power off, of course) and see what I've got.
Old 08-18-2011, 06:08 PM   #5
Sparky
looks sortof like zinsco/sylvania to me dont see the full size too often, usually only mini's
Techy is online now   Reply With Quote
Old 08-18-2011, 06:40 PM   #6
Idiot Emeritus
Agree.
They can be found, but are pretty spendy.
Zinsco, along with FPE are known for not tripping, even with enough current going through them to melt the case. Serious fire hazard.
micromind is online now   Reply With Quote
Old 08-19-2011, 03:02 AM   #7
Bryant used to color code breakers according to amperage.
bobelectric is offline   Reply With Quote
Old 08-19-2011, 03:05 AM   #8
Anyway,time for an upgrade,
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 06:31 PM
Re-Certified, Re-Furbished Circuit Breakers i_need_help Electrical 5 02-10-2011 07:23 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
