Can Someone Check This Work Please? (picture) - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 04:37 PM   #1
langless28's Avatar
Rewards Points: 152
can someone check this work please? (picture)
Hello everyone, my name is Mike, just purchased a house and therefore will be doing alot of renovations/updates and asking alot of questions! First off i am a mechanical engineer and have electrical background but i insist on doing things right the first time and i do not act like i know everything so i do ask for some help along the way.
first off i want to add some shop lights to the unfinished part of the basement; 4 4' shop lights and a single switch on a 15 amp circuit. all the lights are the plug in type so i plan to run boxes in the rafters so each of them can plug in. i plan on using metal octagon boxes with 15 amp tr duplex outlets and a flat metal cover plate. i am using the nm cable connectors like in the picture. i have been told that it is alright to put two nm cables through these connectors. these boxes are 15 in^3 and according to the NEC box fill calc's i should be ok with two 14-2's and a single outlet. my question is that are these cover plates an acceptable way of mounting the outlets? i think i recall a code saying you cannot support the outlet via cover plate but on these the metal tabs are sandwiched between the cover and box as well.
is this setup to code or does someone have another suggestion?
langless28 is offline   Reply With Quote
Old 11-20-2011, 04:50 PM   #2
Master Electrician
Rewards Points: 3,958
To each his own. I have no idea why you would use this set-up iinstead of rectangular plastic nail-on device boxes.
brric is offline   Reply With Quote
Old 11-20-2011, 05:17 PM   #3
Licensed electrician
Rewards Points: 1,870
There was a change awhile ago that the cover screw could not be the only mounting for the device.
Like Bricc, I would use rectangular device boxes and duplex plates.
Code05 (11-20-2011)
Old 11-20-2011, 06:09 PM   #4
langless28's Avatar
Rewards Points: 152
Thanks for thE quick responses, like I said I am still learing. For the plastic rectangular boxes, can you use nylon cover plates? I thought you can only use those with drywall? Thought you had to use metal in unfinished parts of a house?
Old 11-20-2011, 06:33 PM   #5
I've seen the nylon/plastic cover plates used in garages like that and frequently seen them broken.
If you want something sturdy, you could use a 4" square metal box with a single gang metal plaster ring. Then a single metal cover. Like these...
Billy_Bob is offline   Reply With Quote
Old 11-20-2011, 06:53 PM   #6
That is a drywall ring. ghetto to use that exposed.
Industrial raised covers are adequate because they attach in three places.
http://www.garvinindustries.com/Elec...ers/1-2-Raised
G17GUY is offline   Reply With Quote
Old 11-20-2011, 07:24 PM   #7
ghetto? (Translation: Tacky?)
I think that looks cool. (Translation: "sick")
Although I think the raised cover looks cool too...
Old 11-20-2011, 07:26 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
I think you are saying that you will not have drywall on the walls.
In that case I recommend getting a single gang, rectangular metal box that has the lugs for the receptacle that you can screw to.
Put a metal switch cover on it and do not use NM cable use MC type cable as Romex type cables are supposed to be covered in some way or buried in the wall under drywall.
Andy.
AndyGump is offline   Reply With Quote
Old 11-20-2011, 07:35 PM   #9
Master Electrician
If you want to keep driving the cost up why not use GRC and explosion proof boxes and fittings? At the very least WP boxes and covers should be used. After all, a radiator may spring a leak. Why does a simple wiring job need to be so difficult and expensive? Just asking.
The Following User Says Thank You to brric For This Useful Post:
Code05 (11-20-2011)
Old 11-20-2011, 07:45 PM   #10
Boston Fan, get over it
Toofarfromfenwa's Avatar
Wow. Easy there killer. The guy's learning.
(Oh, and he's an engineer, so he over-analyizes everything. My dad's an engineer, and I hate working with him on simple things)
I would use this one.
Looks cleaner, no need for additional wall plates, plain and simple.
Toofarfromfenwa is offline   Reply With Quote
Old 11-20-2011, 07:54 PM   #11
The nylon trimplates from P&S can be bent in half and return to shape.
Code05 (11-20-2011)
Old 11-20-2011, 07:57 PM   #12
langless28's Avatar
Rewards Points: 152
Thanks, as far as myself overanalysising, I prefer to call it weighing all options, I am new to wiring thing that are not in a machine so all the info I can get helps. I will probably use metal boxes with the aforementioned duplex covers. Isn't nm cable alright so as long as its stapled to the rafters? This section of basement will not be finished, it's a utility and work room
Old 11-20-2011, 08:21 PM   #13
Master Electrician
By the time you buy one 4 square and one Garvin cover you could buy 10 23 cubic inch plastic nail-ons. And I wasn't talking to the one who is learning.
Old 11-20-2011, 08:32 PM   #14
If he wanted to go cheap, He would splice inside the light
Old 11-20-2011, 08:49 PM   #15
langless28's Avatar
Rewards Points: 152
Brric, what would you use for covers? Plastic?
Any I appreciate all the responses but I belong to a bunch of other forums (hobby) and respect that everyone can get get along there, everyone is entitled to their own opinion so let's all just mellow out guys.
How many hours to do this work? brainfogbetty Drywall & Plaster 17 10-26-2011 04:17 AM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 08:19 AM
check valve question nsanto17 Plumbing 4 05-20-2011 08:04 AM
Time limit for getting work inspected? tigereye Electrical 8 12-22-2009 02:56 AM
