Old 11-01-2011, 01:44 PM   #1
Question
can somebody explain the pysics behind
when conductor (wire) travels more vertically, why does it get hotter and needs more insulation (MC for going between floors) than when it goes more horizontally? i'm just curious in the physics behind this phenomenon.
thanks
Old 11-01-2011, 02:03 PM   #2
The wire heats up as current flows through it, the greater the number of amperes the more it heats up.
Air around the wire cools it down, the air moves upwards as it warms up by the wire. (warm air rises)
The vertical wire the same air moving vertically tends to follow the wire so the warmer air it gets it doesn't cool the wire higher up as quicklyu compared with a horizontal wire where different air moves upwards all along the length of the wire.
Then the air transfers the heat to other things like the subfloor or top of the stud cavity above.
I think that the effect of cooling on a vertical wire versus a horizontal wire makes little if any differnece in terms of having to use fewer amperes than the wire normally calls for (called derating); I think you do not have to derate because the wire is hung vertically. In other words the original question is for scientific purpose only, those doing electrical work can ignore it.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
amakarevic (11-01-2011), rossfingal (11-01-2011)
Old 11-01-2011, 02:13 PM   #3
thanks. makes sense.
Old 11-01-2011, 03:34 PM   #4
liscenced electrician
never heard this before. makes sense though. If your wires are getting hot, there is a problem
jimmy21 is offline   Reply With Quote
Old 11-01-2011, 04:08 PM   #5
It was a dark and stormy
Yoyizit's Avatar
thanks
Does not make sense according to my mental image of the setup and what I understand about radiative, convective and conductive heat loss.
Can you provide specifics - temps, distances, other factors?
Old 11-01-2011, 10:13 PM   #6
heres what i picture. But i don't believe it has any real world application because wires shouldn't be warm in the first place
The warm air on the vertical wire stays around the wire, while the horizontal wire the air moves away
Can someone please explain these instructions (ceiling fan) NancyNGA Electrical 7 09-06-2011 06:09 PM
MOLD | ? someone explain tawhid111 Building & Construction 4 01-22-2011 08:04 PM
can anyone explain new ductwork layout? peyton HVAC 1 09-01-2010 05:01 AM
200 amp service, someone explain what may have happened? Piedmont Electrical 16 12-12-2007 09:31 PM
Can someone please explain the US 240v system...1 or 2 phases. elkangorito Electrical 8 11-09-2007 10:12 AM
