Can Proximity To Pvc Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 07:25 AM   #1
Just call me Andrew
Rewards Points: 1,020
Can proximity to pvc pipe
I am planning to put 2 non-IC recessed lights in my shower. They will be very close (< 1") to the trap from my upstairs tub. Is this ok?
Also, do they make low profile can lights that are less than 3.5" tall? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-26-2010, 12:54 AM   #2
Union Electrician
goose134's Avatar
If it would make you feel better, I'd put IC in.
The lowest profile cans I've seen are about 5 1/2" high. These were commercial fixtures for four pin fluorescent lights.
goose134 is offline   Reply With Quote
Old 04-26-2010, 01:32 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
here is a link that shows a 4" line voltage and a 2" low voltage. I think that 4" is about the shortest I have ever seen for line voltage lights.
I don't know if any of those lights are acceptable in a shower though. Obviously you will need an appropriate trim for wet locations.
Old 04-26-2010, 07:24 AM   #4
Just call me Andrew
Is there any type of heat shield I can put on the pipe to reflect it elsewhere?
I have very little vertical room to install this light, i think the only way I can get it in is to use an old-work light and mount it to the drywall later. The ones that have bars extending to two joists would hit the plumbing.
Andrew
Old 04-27-2010, 10:09 AM   #5
Just call me Andrew
Any other ideas? Thanks.
Andrew
Old 04-28-2010, 07:04 AM   #6
Just call me Andrew
Just passed rough inspection.
I asked the inspector about the can lights - he said you only have to be 1/2" from PVC. That seems kind of close to me. He said if I was worried I could wrap header tape (auto part) around the pipe. It's used to repel heat from plastic parts in cars apparently.
Andrew
Old 05-01-2010, 12:49 PM   #7
Just call me Andrew
This is the stuff I bought. I wrapped around the PVC pipe, kind of expensive ($15 for a square foot) but worth it for the peace of mind:
http://www.napaonline.com/Search/Det...081_0006560691
Andrew
Old 05-01-2010, 01:31 PM   #8
PVC melts at 75C, which is too hot to touch.
I doubt that the surface of this can gets that hot, but even if it does you've got an air space between the can and the pipe.
Old 05-01-2010, 01:49 PM   #9
Just call me Andrew
True. The inspector said i only need 1/2", I just did this as a precaution.
Andrew
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
