Can A Polarized Plug Be Hardwired. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2007, 05:43 PM   #1
Can a polarized plug be hardwired.
My wife bought a hanging chandelier with a polarized plug. I'd like to install this where a ceiling fan is now. The cord runs through the normal mounting bracket and a copper wire (yellow green sheath) is connected at the bracket. Where the light bulb is, the label says " 60Hz AC Only" There isn't an outlet nearby so I would like to have it hardwired. Is this possible? Thanks
kdodkdod is offline   Reply With Quote
Old 12-29-2007, 08:08 PM   #2
MinConst's Avatar
If this is a light only then yes you can hard wire it. If you want to keep polarity the large side of the plug will be the common or white wire. You can follow this side of the plug to the wire, it will be in line. Also one side of the wire will have some sort of marking, a line or two molded into the wire insulator or something. But with a light it really doesn't matter which is which.
Minichillo's Construction
I will never leave you hanging!
One Man Shops
MinConst is offline   Reply With Quote
Old 12-29-2007, 08:21 PM   #3
Rewards Points: 266
Is it a "swag" light and consists of a chandelier type fixture on a long chain with the cord woven through the chain? Does it have a pull chain?
Be careful. NEC 200.10 (C) requires the screw shell be connected to the (white) grounded neutral conductor for obvious reasons. This is usually connected to the side of the lamp cord which is ribbed or has a rib embossed in it.
If you have an overhead ceiling box on which you want to install it on, you will need to buy a fixture canopy and the appropriate hardware ( fixture strap, hickeys, nipples) to convert it to the more permanent style. The chain and cord will most likely need to be shortened.
junkcollector is offline   Reply With Quote
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
Hardwire a polarized plug Mrsfixit Electrical 3 10-23-2007 05:24 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 12:34 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
