Can a polarized plug be hardwired.
My wife bought a hanging chandelier with a polarized plug. I'd like to install this where a ceiling fan is now. The cord runs through the normal mounting bracket and a copper wire (yellow green sheath) is connected at the bracket. Where the light bulb is, the label says " 60Hz AC Only" There isn't an outlet nearby so I would like to have it hardwired. Is this possible? Thanks
If this is a light only then yes you can hard wire it. If you want to keep polarity the large side of the plug will be the common or white wire. You can follow this side of the plug to the wire, it will be in line. Also one side of the wire will have some sort of marking, a line or two molded into the wire insulator or something. But with a light it really doesn't matter which is which.
Is it a "swag" light and consists of a chandelier type fixture on a long chain with the cord woven through the chain? Does it have a pull chain?
If you have an overhead ceiling box on which you want to install it on, you will need to buy a fixture canopy and the appropriate hardware ( fixture strap, hickeys, nipples) to convert it to the more permanent style. The chain and cord will most likely need to be shortened. |
| All times are GMT -4. The time now is 05:41 AM. |
