Can A Pigtail Light Switch To Another Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 12:47 PM   #1
can a pigtail light switch to another light switch
Can I pigtail from another room light switch to another room light switch? And if I do will it work normal.
dimples2132 is offline   Reply With Quote
Old 01-08-2012, 12:53 PM   #2
Julius793's Avatar
We need some more info but assuming you want to take power from one room to the next and the circuit can handle it there's no problem
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-08-2012, 01:07 PM   #3
MarginallyQualified
Rewards Points: 2,464
The (still amateurish) term is "daisy chain".
IF (big if generally) there is unswitched feed at the 1st switch... yes.
Generally though you'll need to daisy chain from light to light...
then run a new switch leg.
define normal.
Old 01-08-2012, 06:53 PM   #4
joed's Avatar
Rewards Points: 11,556
The light switch might be a switch loop and you can not run another light from it. If the switch has only two wires both connected to the switch then you don't have a neutral. Find another power source for your new fixture.
Looking for a special light switch for task lighting shazapple Electrical 3 01-02-2012 10:39 PM
Newbie - fixing a switch and adding a light telechick Electrical 3 09-14-2011 09:59 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 11:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
