#1 |
Can NM come in contact with ductwork from residential kitchen range hood?
Hello,
I would like to install a ducted 30 inch range hood in my residential kitchen. Currently there is not ductwork. I would like to run a 3.25x10 flat duct inside a kitchen wall to accomplish this, however there is existing NM electrical cable inside the wall cavity that I would like to use. Is it acceptable for NM to come in contact with ductwork from a residential kitchen range hood? Thanks! |
#2 |
DIYer
NM must be protected from physical damage. If it were me, I'd find some way to separate the two. Can you put a furring strip in between the duct and the wire?
#3 |
Thanks for the reply. There is one tight section that only has about 3/4 inch clearance. But there would still be room to protect the wire in some way. I read in another post from a similar question a suggestion to put in a strip of insulation.
| Display Modes | |
| Range hood wiring needs tweaking | RedHelix | Electrical | 4 | 12-02-2010 02:31 PM |
| range hood ventilation | Millertyme | Appliances | 0 | 08-31-2010 08:31 PM |
| Range Hood venting questions | Crashless | Remodeling | 5 | 04-13-2008 10:30 PM |
| Same Circuit: Range Hood, DW, and GD? | atty_toconnor | Electrical | 4 | 04-08-2008 05:43 PM |
| Can I Wire a range hood to an exhisting outlet? | skellies | Electrical | 2 | 05-09-2006 05:06 PM |
