Can Location - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2009, 05:25 PM   #1
Rewards Points: 264
can location
I am going to install can lights in the den. 5", IC rated, Halo brand.
I need some suggestions on layout-
Any general rules of thumb?
Any where to look on the web for sample layout?
The room is approx 11' by 18'.
Comments appreciated!
7echo is offline   Reply With Quote
Old 09-01-2009, 06:23 AM   #2
Rewards Points: 264
bump
How far from the wall are the usually set?
Old 09-01-2009, 06:47 AM   #3
Are you looking to wash the walls with light
Or just light up the room?
Old 09-01-2009, 07:36 AM   #4
Rewards Points: 264
Just want to have general lighting. I can center them at 25.5" inches or 37" inches off the walls. I don't want to change framing so I need to work with one of those 2 locations. I am thinking 4 lights in 2 rows at one of those distances from the wall, then maybe 3 more down the middle, off set from the 4 against the wall. Might put them on 2 switches, but more likely a dimmer.
Old 09-01-2009, 07:49 AM   #5
I think I'd go with the 37"
That would give you 3' from the walls & 5' between the cans
That puts the light approx over anyone sitting on a couch/chair if they are reading
hole for basement bathroom vent location jeeper Building & Construction 4 04-12-2009 11:25 AM
Well Pressure Switch Location dshcs Plumbing 4 02-05-2009 09:04 AM
Number, Size, and Location of Celing Vents GeauxCajuns82 HVAC 7 11-13-2008 10:40 AM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
