Can Lights And Wire Support. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 08:22 AM   #1
Can lights and wire support.
I am wondering what the nec 2011 code for can lights , connectors and stapling the wire near the can light.
So my can lights are in place, wired, with strain releif connectors on all wires in and out of the can lights. sll the wiring except the switch wire goes through the joists.
my question: I am looking at it now and wondering if i need to re wire all 16 can lighs and make the wires longer so i can put a small loop of wire near each can light that i can stape to the joist. Is this required by the current 2011 NEC?
bf514921 is offline   Reply With Quote
Old 07-14-2012, 08:39 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Yes, you need to staple within 12" of the box on the light, measured along the cable.
Speedy Petey is online now   Reply With Quote
Old 07-14-2012, 08:42 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You need to staple romex 12" from each box (or can light) and 4' 6" there after.
So if your piece of wire is 11' long, you will need 3 staples.
If the wire runs perpendicular thru bored holes, that is considered secured and supported.
Old 07-14-2012, 08:43 AM   #4
k_buz's Avatar
I am REALLY curious about these strain relief connectors. Could you post a picture?
Old 07-14-2012, 08:44 AM   #5
I think it's a DIY term for romex connector.
Old 07-14-2012, 08:58 AM   #6
never heard them called anything else i think they are what you call romex connectors.
http://www.grainger.com/Grainger/cab...3As&sst=subset
wait perpendicular to the bored holes is considered support?
so if my bored hole is within 8 inches of the can light i don't need a staple?
maybe i should just spring for the 130$ for copy of the 2011 NEC so i can just read it. I hate not being able to see a standard i am supposed to meet.
Old 07-14-2012, 09:07 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
You still need a staple near the can.
Old 07-14-2012, 09:30 AM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I don't see where I have to measure along the length of the cable, I just need a support within 12" of the box, measured any direction I want.
Old 07-14-2012, 09:40 AM   #9
You're right.
314.17 Exception specifically states that the measurement is to be "measured along the sheath". I always though 334.30 had the same wording.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (07-14-2012)
Old 07-14-2012, 09:46 AM   #10
E2 Electrician
Now, check out 334.30 (a) Pretty clear to me that if the hole in the joist is within 12" of the junction box on the recess can, then he has met the critera of securing and supporting. Thus, no staple is required.
Old 07-14-2012, 09:57 AM   #11
think i odn't understand. I understand the supporting wire every 4 feet when running parrallel to a joist, makes sense. i think i dont understand what suffices for support for a can light. my wire is perpendicular to the joists, almost all the wire is. i think i still need a stape even with the connectors and support so close to the can lights. i will try to add a picture shortly hopefully this makes my eplanation a little clearer.
Old 07-14-2012, 09:59 AM   #12
E2 Electrician
I'm betting you don't. but put one in if you so desire.
Old 07-14-2012, 10:34 AM   #13
i dont really want to, i just want to meet whatever is required in the code.
Old 07-14-2012, 10:57 AM   #14
E2 Electrician
Your picture looks fine. IMO, you met the requirements of 334.30 (A)
Old 07-15-2012, 10:06 AM   #15
do i need to have an extra l loop of wire near the can light?
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 10:30 AM
wiring xenon puck lights... Bagatelle Electrical 6 12-04-2011 03:05 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Installing Pot Lights - 12AWG and 14/2 wire ... help! njchan Electrical 4 04-10-2008 06:50 PM
