Can Lights In Insulated, Existing Construction? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 08:59 PM   #1
Can lights in insulated, existing construction?
Hi I'm just wondering if theres a way to install potlights in existing construction in a ceiling that has insulation. I've seen a few products for other applications, such as old construction fixtures where no insulation is present. I'm just wondering what you'd do if you cut into a ceiling and found insulation, is there any types of fixtures for old construction that allow direct contact with IC that can be shoved up and fastened through a simple potlight hole in the ceiling?
mtr_can is offline   Reply With Quote
Old 07-16-2011, 09:03 PM   #2
Licensed electrician
Rewards Points: 1,284
Except for a 4" can, you should not have too much trouble finding a retrofit IC rated housing.
mtr_can (07-17-2011)
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Commercial Electric Pot Lights in Insulated Basement Ceiling balithecat Electrical 4 03-14-2011 06:46 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Upgrading can lights to insulated? juliejules4 Electrical 2 12-03-2006 05:25 PM
