Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 06:34 AM   #1
Can lights
Have a little problem. My house is 107 years old. Built a wrap around porch on front. Am adding 5 can lights. Problem is they want me to ground the lights. But my house has no grounds because its old. What would be the easiest way to ground these lights?
Kurt1968 is offline   Reply With Quote
Old 09-22-2010, 07:11 AM   #2
The house is grandfathered, the new work is not. Ground the fixtures with new wiring and run a new circuit back to the panel for a proper ground.
Old 09-22-2010, 07:54 AM   #3
Now is the time to establish a ground. One is obtainable via your water pipes. Otherwise a ground rod should be driven into the earth close to base of your house.
oilseal is offline   Reply With Quote
Old 09-22-2010, 07:56 AM   #4
I was hoping you wouldnt say that. Thats going to be a big project. I already have power there from a light that was on old porch. But have to put new wiring for the rest of the lights. Well time for a new plan of attack.
Old 09-22-2010, 08:54 AM   #5
Licensed electrician
Rewards Points: 1,046
Both of these suggestions are incorrect. You cannot just ground to a nearby water line. The ground must originate from specific locations allowed in 250.130(C).
Also ground rods have nothing to do with providing an equipment grounding conductor to ground a receptacle. Rods are for high voltage events like lightning.
Old 09-22-2010, 10:06 AM   #6
I had a new panel installed a couple years ago. And central air put in so i image the new panel is grounded. So looks like im going to have to run a new line.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
