Old 12-19-2011, 12:39 PM   #1
Can lighting legs do not shut
I have purchased the can lights or recessed lights and the removed the old lighting, but now the legs will not adjust over the existing dry wall so it is partially coming out. What should I do? The pick is for the can kit that I purchased. I can't get the little prongs to adjust out, maybe the drywall is to thick?
lexnupe is offline   Reply With Quote
Old 12-19-2011, 12:42 PM   #2
Mad Scientist
I can't see too clearly in that picture, but it looks like those spring clips have a couple different slots they can be installed in for different drywall thickness.
McSteve is offline   Reply With Quote
Old 12-19-2011, 02:13 PM   #3
I thought that too once you mentioned, but no dice. It is as if there is nothing for it to grab onto.
Old 12-19-2011, 02:34 PM   #4
ink
DIY Enthusiast
ink's Avatar
Does the trim piece help hold it in maybe? Those look like the Halo retrofit cans... I haven't used them; just the new-work ones. I bet you could find some info on their website?
inK
Hammer in Hand, Dad on Speed Dial
ink is offline   Reply With Quote
Old 12-19-2011, 03:54 PM   #5
How thick is your drywall?
When I installed some I vaguely remember using the end of a straight-slot screwdriver to drive the retainer home. Some seemed to go in easy as pie, others were a bear for some reason.
bob22 is offline   Reply With Quote
Old 12-19-2011, 04:16 PM   #6
Can you explain that process, I am about ready to just punch holes in the wall and use the natural light during the day and say who gives s*** at night.
Old 12-19-2011, 04:18 PM   #7
you push the clip into the fixture with your hand until the top part is outside the can, then place your screwdriver in the small slot/nib and continue to push straight up, and the clip should lock in.
Techy is offline   Reply With Quote
Old 12-19-2011, 04:43 PM   #8
A bit vague in spots but overall good:
http://www.youtube.com/watch?v=TQbcWVM23yg
Old 12-19-2011, 07:47 PM   #9
Worked guys thanks, there is a groove in the legs that allows you to place a flat head screw driver in once you get the unit in you press the legs up through the groove until it locks. It was odd because they have a cover over them and unless your know to take them off your kind off screwed.
Old 12-20-2011, 07:15 AM   #10
Glad to hear it worked out; first time for a lot of things seems more difficult than it is once you know the way.
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 04:12 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
