Can Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2008, 10:31 PM   #1
Can Lighting
I am involved in a bathroom remodel....
I have recently installed 5" ceiling can lights in my shower. After installing the 2 can lights we relaized that they were non-ic rated. I purchased the cans at my local Lowe's and they do not carry 5" IC rated cans. Do I have any options other than changing to 6" IC rated cans, and having to try and recut and fit the larger cannisters?
The cans are cut through sitting against a truss on the east side. the trusses are on 24" centers. I have atleast 18" of clearance in all directions. The crawl space has anywhere from 18" to 36" of clearance above the cannisters. My crawl space has approximately knee deep insulation.
Sugesstions please?????????
MIMO510 is offline   Reply With Quote
Old 10-16-2008, 03:02 PM   #2
why do you need IC rated... isn't that only if you have insulation between the ceiling joists? normally we don't have that... if you don't have that... why do you need IC rated?
Last edited by AtlanticWBConst.; 10-25-2008 at 07:11 AM. Reason: Site Rules Violation: Web Link Removed
KUIPORNG is offline   Reply With Quote
Old 10-16-2008, 03:51 PM   #3
The crawl space is insulated between the joists. The insulation is blown in and approximately knee deep.
Any suggestions, or can I use the non-ic rated?
Old 10-16-2008, 03:58 PM   #4
Electrician
Go to a local electrical supply house and get 5" insulated cans.
chris75 is offline   Reply With Quote
Old 10-19-2008, 11:27 AM   #5
Creative Electrician
410.116 says that non-ic can be used, but the recessed parts must be 1/2 in. away from combustible materials.
(NEC 2008)
BeastinBlack is offline   Reply With Quote
Old 10-19-2008, 11:43 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
And the instructions of non-IC cans say to keep insulation 3" away.
Old 10-19-2008, 01:05 PM   #7
Thumbs up
Thank-you for the information. I will clear the insulation away and build a flashing guard.
Old 10-19-2008, 03:00 PM   #8
Electrician
If the insulation is required to be installed, then removing it is only creating another violation.
Linking the 5amp lighting live to the 13amp neutral causes tripping of the rcb. Why? StevieV Electrical 8 08-24-2008 09:42 PM
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 02:36 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
