Can Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 02:38 PM   #1
jburd964's Avatar
Rewards Points: 166
Can lighting
How many square feet per can light with 8' ceiling?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 02-13-2013, 06:32 PM   #2
Licensed electrician
Rewards Points: 1,766
What size fixture, bulb and trim? What is the room? Different rooms require different amounts of light.
Old 02-13-2013, 06:39 PM   #3
jburd964's Avatar
Rewards Points: 166
Stand size 6" can and bulb it's in living room.
Old 02-13-2013, 08:12 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 550
I think I remember reading a 6" can in an 8' ceiling will give an 8' spread on the floor.
Or I could have made this up!
jbfan is online now   Reply With Quote
Old 02-13-2013, 09:06 PM   #5
That is a rough guide.
Old 02-13-2013, 09:13 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Also depends on what kind of bulb and wattage you put in....
This is a pic of one part of my garage....I have 16 6" cans in it....500 sq ft...each can has a 23w CFL.
When in doubt...put in more than you think you need....use LED bulbs and connect a dimmer.
Old 02-16-2013, 04:56 AM   #7
jburd964's Avatar
Rewards Points: 166
I found a formal. Room square footage x 1.5 divided by bulb wattage equals number of bulbs.
Old 02-16-2013, 06:34 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
I don't use sq footage. I use the dimensions of the room and lay out the lights according to the footprint.
Telling you how many lights is one thing, how to lay them out is another. What if the guide say you need 11 lights, how would you lay them out?
Old 02-16-2013, 07:14 AM   #9
This so called formula does nothing to account for the difference in lighting levels needed in a kitchen or a family room, work surface height, beam spread from the bulb, surface reflectivity or trim selections. I would consider it almost worthless.
Speedy Petey (02-16-2013)
Old 02-16-2013, 01:35 PM   #10
Missouri Bound's Avatar
Without knowing the fixture and lamp lumen output and how bright you want the room, there is no way to accurately answer you.
Do you want it your way or the right way?
Old 02-16-2013, 02:08 PM   #11
Rewards Points: 1,192
Mfg. should have a cut sheet on lumen and lighting throw.
bobelectric is offline   Reply With Quote
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
