Can Light Trim For Porch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2008, 08:28 PM   #1
Rewards Points: 89
Can light trim for porch
Am putting 6" can light fixtures on porch. Would "shower" trim rings with solid glass covers work?
nicksteel is offline   Reply With Quote
Old 08-20-2008, 09:11 PM   #2
Electrician
You can use any trim rated for a damp location.
chris75 is offline   Reply With Quote
Old 08-20-2008, 09:20 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Be aware, some shower trims I've seen have the glass held in by pins. You have to lift & turn them to get them out, and because the glass is 'a little loose' the wind in a porch may cause them to rattle some.
Old 08-20-2008, 09:39 PM   #4
Electrician
I personally would just use an open baffle trim.
Old 08-21-2008, 07:32 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
Same here! A shower trim will limit you to max 40 watt bulb.
jbfan is online now   Reply With Quote
Old 08-21-2008, 09:08 AM   #6
You can check here for your trims :
http://www.gordonelectricsupply.com/...arch&text=ert7
Woodyh1 is offline   Reply With Quote
Old 08-21-2008, 09:22 AM   #7
Rewards Points: 89
Thanks, guys.
Old 08-21-2008, 11:41 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
http://www.SPAMelectricsupply.com/in...arch&text=ert7
Gee Woody,you're all over the place with this SPAM, aren't you?
Installing recessed light trim helpless handyman Electrical 18 07-30-2009 05:35 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
