Can Light Touching Air Duct Insulation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 06:44 PM   #1
Can light touching air duct insulation
If I put a 4 inch non ic can light thats 45 watts touching the insualtion around the air duct, what are the chances of the insulation on the air duct catching on fire? Or what other problems may occur?
gilbert.ayala77 is offline   Reply With Quote
Old 08-16-2010, 07:02 PM   #2
Electrician
Proby's Avatar
Make sure the recessed light is IC rated. IC rated luminaires are rated for direct contact with insulation.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-17-2010, 08:47 AM   #3
Rewards Points: 156
For the purposes of this discussion, you can consider the chance of fire to be 100%. (because no one will know the actual odds, and no one will advise you to put a non-IC-rated fixture in contact with insulation.)
Other problems that may occur:
If the duct vibrates during operation, you'll most likely burn out light bulbs faster.
moondawg is offline   Reply With Quote
Old 08-17-2010, 08:49 AM   #4
Electrician
Proby's Avatar
Just to clarify this thread, the OP added "non ic" to his/her post after I made my post.
Old 08-17-2010, 08:50 AM   #5
Rewards Points: 156
I saw the edit and figured that was the case. Don't worry, we know that you know your stuff.
Old 08-17-2010, 09:09 AM   #6
Electrician
Proby's Avatar
Apparently he/she didn't like our answers because he/she went to the sister forum for electricians only, lied during registration, and then posted the same question:
http://www.electriciantalk.com/f2/no...ulation-15833/
The Following User Says Thank You to Proby For This Useful Post:
frenchelectrican (08-17-2010)
Old 08-17-2010, 11:59 AM   #7
" Euro " electrician
frenchelectrican's Avatar
If you going to installed a recessed can luminaire next to the air ductwork you must have IC rated can do NOT use the non IC can at all due the safety reason or just move the ductwork or relocated it.
Myself I will try to advoid the ductwork much as I can as long I can keep at least 3 inches away from it.
Merci.
Marc
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
POT light in Return Air Duct Jst. Bay?? mfleming Electrical 3 05-02-2009 02:54 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
