Can Light Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2007, 01:22 PM   #1
can light question
I've got a question for any electricians out there.
I've got a can light on my 2nd floor that is supposed to be rated for contact with insulation. So since it is in the attic, there is insulation now on it.
It would once in a while turn off after apparantely heating up too much- and later work fine when it cooled. Now it won't come back on at all (and yes the bulb is fine and no breakers tripped).
My question is whether the whole can likely needs replaced? Are the thermal sensors designed to trip and stay off or do I just have a bad one. If I can just change the sensor (from below-inside the can) and move the insulation away from the light I'd prefer that than crawling around in the attic actually swapping the whole can.
I know, the easy answer is to call an electrician but I do have skills in basic electrical. Changing a can light, which is what I'll do if I can't repair the old one, is well within my abilities.
trptman is offline   Reply With Quote
Old 04-18-2007, 02:42 PM   #2
It is likely the proclaim bulb holder got damaged, bad contact, metail oxidized..etc. and no longer working... My Dad's apartment have these guys damage by overheating... and I replace one of them by replacing the proclaim bulb holder...
KUIPORNG is offline   Reply With Quote
Old 04-18-2007, 03:45 PM   #3
So Cal Electrician
Send a message via Yahoo to hbsparky
probably going to be just as cheap and easy to replace the fixture rather than just the thermocouple. Just make sure it is an IC rated fixture
hbsparky is offline   Reply With Quote
Old 04-18-2007, 03:48 PM   #4
the proclaim socket cost $4 but the insulated can probably cost around $30 or more...
Old 04-18-2007, 04:27 PM   #5
So Cal Electrician
do you mean porcelin? socket?
Old 04-18-2007, 04:31 PM   #6
I can't remember the spelling... porcelain it should be after checking the spelling...
those part where you rotate the light bulb onto...
Old 04-18-2007, 04:33 PM   #7
So Cal Electrician
the failure rate on those is near zero, if it was going off and coming back on after it cooled, it has a 135 degree thermocouple in the can, which by the way, a 6 inch halo IC rated new construction can is only 7.33 at the big box store.
Old 04-18-2007, 04:41 PM   #8
My father condo has two of these guy fail and I replace one of them for him and it works... if it is close to zero failurer, you won't find such part in HD which I bought ...
Old 04-18-2007, 04:45 PM   #9
So Cal Electrician
then your father is using the wrong bulbs for the cans. Those don't just go out. And if you replaced it and it worked, then you probably took out the thermocouple as well. How long have you been in the trade?
Old 04-18-2007, 05:06 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
Old 04-18-2007, 05:34 PM   #11
So Cal Electrician
heh
Old 04-18-2007, 06:08 PM   #12
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
ha, ha
- Build Well -
Old 04-19-2007, 12:27 PM   #13
The can light isn't costly itself, but where it is in the attic is the pain to get at. Its out near the edge where the roof is sloping down to nothing. Its not impossible to get at, but just a pain. What I was hoping was that I could get a replacement thermal sensor and just push the insulation away from the light with a broom or something to extend my reach. If not, I guess I'll just suck it up and get dirty laying in the blown in insulation to get at the light.
Old 04-19-2007, 06:11 PM   #14
Recess can lights can be accessed from in the room that they light.
They come apart. It is not fun working in the small hole, but you can get to all the parts.
Master Electrician
jwhite is offline   Reply With Quote
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
